    DWC not starting after update try
    Firmware installation
    923
    • Tinchusundefined
      Tinchus @chrishamm
      @chrishamm I do have ssh connection to the printer, is there any way I can aluch that command from that ssh conection console in the printer?
      • chrishammundefined
        chrishamm administrators @Tinchus
        @tinchus You can now try to upgrade your system using apt update/apt dist-upgrade. The version that we released today should fix your issue, and the upgrade command does not query the affected object model key.
        Duet software engineer
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @chrishamm
          @chrishamm Hello. The update fixed the issue. Sadly, I had scheduled the execution of your requested command for monday, so I cant provide you with the output of that command in order for you to fully diagnose the problem.
          But this update did the magic. THANKS!
