    ExecOnMcode
    Plugins for DWC and DSF
    11
    76
    6.3k
    • CrazyCreatorundefined
      CrazyCreator
      @Falcounet
      I found your v_0.3 on GitHub ... But when i try to Install, i see no PopUp with Installroutine.
      http://www.crazycreatorcube.com
      Falcounetundefined 1 Reply Last reply Reply Quote 0
      • Falcounetundefined
        Falcounet @CrazyCreator
        @CrazyCreator That version is still for 3.4 and it installs fine here.
        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
          CrazyCreator @Falcounet
          @Falcounet
          I thought it was already for the latest 3.5... Because you just released it.
          Is there a beta version to test?
            @CrazyCreator The issue has been fixed in DWC 3.5b2 so I will release a beta version for 3.5 only when 3.5b2 will be released.
              Falcounet
              ExecOnMcode v0.4 has been released.
              This version is still for 3.4 versions of DWC, starting from 3.4.5.
              Changes :
              • Append m-code parameters as command arguments (Thanks @brendon !)
              • Remove the flush option (Custom G-Code should always flush the code channel)
              • Use the DWC connector to make HTTP request
              • File architecture has been changed so the build_plugin script also bundles dsf and sd files
                @Falcounet
                A little side info:
                If try to install the new version from github (the 0.4) ... Only for test as well.
                I move the zip-file with drag&drop to the Button (Install Plugin) in DWC ... but nothing.
                I know is the wrong version, i wrote only for info.
                  @CrazyCreator As said earlier, there is an issue related to the plugin permissions in 3.5b1 and it will be fixed in 3.5b2.
                  There is no point trying to install the plugin targeting version 3.4.5 in version 3.5 of DWC.
                    @Falcounet
                    i know ... just for info 😉 All fine
                    • scumdeadundefined
                      scumdead
                      It is not possible to install it in 3.4.6?
                      Thank you.
                        Falcounet @scumdead
                        @scumdead I released a new version with fixed version dependencies so it installs fine on DWC 3.4.6.
                        Thanks for reporting the problem.
                        Forum-userundefined 1 Reply Last reply Reply Quote 0
                        • Forum-userundefined
                          Forum-user @Falcounet
                          @Falcounet does this plugin support 3.5? running into issues with the new bookworm build.
                            Falcounet
                            ExecOnMcode v0.6 has been released.
                            This version now supports DWC 3.5
