duet3 mini5 stuck
Board v0.5
Seems to no longer boot completely. When connected via USB to a windows machine it does not appear in the Device Manager. I have a steady green and red LED when connected to the PC. Confirmed USB cable is OK.
When connected to 24V the behavior is the same, with the blue and amber LED's lit as well.
The SBC will not connect to the board as well.
I do not know if there is a way to "erase" the firmware as stated here: https://docs.duet3d.com/User_manual/Troubleshooting/Duet_wont_respond
Any help would be appreciated.
@wally3d said in duet3 mini5 stuck:
Yes there is.
https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#duet-3-mini-5-wifiethernet
@phaedrux Thanks, that did the trick.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
