    X Axis not homeing
    535
    • fragleundefined
      fragle
      i have an strange problem, because my core xy machine was already running, but now i can not home the x Axis.
      If i home X septeratly, the printhead goes one to+X not in the direction of the endstop ( on the left side )
      If i trigger the endstops manally M119 shows an trigged endstop
      If i move +X +Y everthing is working fine.
      config.g ```
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.12 on Tue Aug 23 2022 15:15:36 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Duet 3" ; set printer name
      M669 K1 ; select CoreXY mode
      M569 P0.0 S0 ; physical drive 0.0 goes forwards
      M569 P0.1 S0 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z600.00 E415.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X8000.00 Y8000.00 Z780.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z150.00 E1500.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z1300 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X250 Y250 Z380 S0 ; set axis maxima
      M574 X1 S1 P"!io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      ; Filament Sensor
      ;M591 D0 P3 C"io3.in" S1 A1 ; filament monitor connected to E0_stop
      ;M591 D0 ; display filament sensor parameters for extruder drive 0
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      ;M307 H0 B1 S1.00 R0.04 ; enable bang-bang mode for the bed heater and set PWM limit
      M307 H0 B0 S1.00 R0.4
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M307 H1 R3.784 K1.110:0.766 D4.87 E1.35 S1.00 B0 V23.9
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
      homex.g
      ; homex.g
      ; called to home the X axis
      G91 ; relative positioning
      G1 H1 X-250 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F6000 ; go back a few mm
      G1 H1 X-250 F360 ; move slowly to X axis endstop once more (second pass)
      G90 ; absolute positioning
      homey.g
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F6000 ; go back a few mm
      G1 H1 Y-215 F360 ; move slowly to Y axis endstop once more (second pass)
      homeall.g
      ; homeall.g
      ; called to home all axes
      G1 H1 Z-380 F1800 ; move Z down until the endstop is triggered
      G1 H1 Y-250 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H1 Y-250 F360 ; move slowly to Y axis endstop once more (second pass)
      G1 H2 Z-5 F6000 ; lower Z again
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      best regards
      Chris
        jay_s_uk @fragle
        @fragle if you have the axis in the middle of the travel and send something like G92 X100, can you then jog the head to the left in the X axis using DWC?
        fragleundefined 1 Reply Last reply Reply Quote 0
        • fragleundefined
          fragle @jay_s_uk
          @jay_s_uk Yes, i can move the print head in the machine movement sector of DWC
            jay_s_uk @fragle
            @fragle thats a good first step then.
            I'm assuming when you command it to move in -x that it moves left?
            How far does it move to the right when you try and home X? Would you say roughly 5mm or more?
            • fragleundefined
              fragle @jay_s_uk
              @jay_s_uk , i can move to+- without problems at the dwc.
              Indeed if i press home X in the DWC, the printhead moves around 5mm.
                jay_s_uk @fragle
                @fragle my guess is you're getting interference on your endstop wiring so the firmware thinks its homed. what type of endstop is it?
                • fragleundefined
                  fragle @jay_s_uk
                  @jay_s_uk mechanical omron endstops, if check M119, all endstop states are in the right condition
                    jay_s_uk @fragle
                    @fragle i would change the wiring on the switch from NO (normally open) to NC (normally closed).
                    Although they may show as working fine using M119, that wouldn't stop interference.
                    If you can't change the wiring of the switch (which I would highly recommend (and if you do, remove the ! from the pin name)) then look at separating the endstop wiring away from everything else, especially stepper motor wiring.
                    • fragleundefined
                      fragle @jay_s_uk
                      @jay_s_uk i seperated the endstop wires a little bit from the stepper wires and now the endstop is back in normal service.
                      Thanks for the good idea, but i am wondering, where the problems came from.
                      now it is working and printing normally. Thank you very much for your help.
                        jay_s_uk @fragle
                        @fragle it comes from interference.
                        Normally open switches, in the untriggered state, don't provide a signal so any electromagnetic interference could induce a signal and give the appearance that the switch has been triggered.
                        Normally closed switches always send a signal unless triggered, so they are immune to electromagnetic interference, hence why they are recommended.
