Solved Bed heater faulting out after RRF 3.0 and later update
I'm currently running RRF 3.4 on a corexy machine with an E3D PCB bed heater that worked fine til updating. Now it faults out saying it's heating too slowly. Here's my config.g. Let me know if more info is needed. I appreciate any help.
Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 24 2022 20:50:56 GMT-0500 (Eastern Standard Time); General preferences
M550 P"CoreXY 1" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z400.00 E852 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X320 Y185 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
;M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
M574 Z1 S2 ; Define Z to use Probe. Home to Min; Z-Probe
M558 P9 C"^zprobe.in" H5 F120 T6000
G31 P500 X-41.8 Y32.2 Z2.1
M557 X10:320 Y0:190 S50 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure M307 H0 R0.378 K0.438:0.000 D2.11 E1.35 S1.00 B0sensor 0 as thermistor on pin bedtemp
M307 H0 R0.352 K0.487:0.000 D1.76 E1.35 S1.00 B0; disable bang-bang mode for the bed heater and set PWM limit
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M501 -
@gbusy24 have you reran PID tuning? the algorithm changed around RRF3.2
@jay_s_uk I just reran it.
@gbusy24 and is it still the same? what values do you have in config-override? are they different values to the ones in config?
@jay_s_uk They're different.
; config-override.g file generated in response to M500 at 2022-06-26 17:57
; Heater model parameters
M307 H0 R2.429 K0.714:0.000 D5.50 E1.00 S1.00 B0
M307 H1 R2.429 K0.714:0.000 D5.50 E1.00 S1.00 B0 V0.0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
@gbusy24 I guess I need to do an M500.
@gbusy24 assuming you haven't rebooted yes. If you have rebooted and the values in config are the correct ones, rerun that line (copy and paste it into the console) and then M500.
Or you could remove M501 at the end of your config and reboot -
@jay_s_uk I haven't rebooted and ran M500, but e-thing stays the same in config.g- override. Shouldn't they change?
@gbusy24 yes, they should change. i suggest repid tuning and running M500 straight afterwards
@jay_s_uk Okay
@jay_s_uk Thanks for your help. Everything is sorted out and working proper now. No more faulting out.
@gbusy24 glad to hear it
