    Euclid facility
    91
    4.7k
    • A Former User?
      A Former User @Phaedrux
      @phaedrux
      I deleted my deploy and retract and I didn't save
        Phaedrux Moderator @A Former User
        @sgk said in Euclid facility:
        retractprobe.g homez.g homeall.g deployprobe.g config.g bed.g
        πŸ‘
        want the files in raw or it goes in ZIP
        Good thing you uploaded them here.
        • A Former User?
          @phaedrux yes niceπŸ‘
          • A Former User?
            A Former User @A Former User
            it works but not very well every time the probe feels it comes home
            • A Former User?
              I will make a video
              • A Former User?
                and above all it does not balance the left and right bed
                • A Former User?
                  https://youtu.be/Iv2z8CIwCVc
                  • A Former User?
                    jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                    • jumpedwithbothfeetundefined
                      jumpedwithbothfeet @A Former User
                      @sgk Have you changed bed.g to what @Phaedrux suggested? it should now look like this -
                      ; bed.g
                      ; generated by Ben Levi - BLV developer as a basic version
                      M561 												; clear any bed transform
                      G91               									; relative positioning
                      G1 H2 Z5 F6000   									; lift Z relative to current position
                      G90              									; absolute positioning
                      G28 												; home all
                      M401 ; deploy Z probe (omit if using bltouch)
                      G30 P0 X10 Y175 Z-99999 							; probe near a leadscrew, half way along Y axis
                      G30 P1 X330 Y175 Z-99999 S2 						; probe near a leadscrew and calibrate 2 motors
                      M402 ; retract probe (omit if using bltouch)
                      M291 P"Leveling finished !" R"Probing.." S1 T2
                      once you have done that go into your deployprobe.g find the line that says -
                      G0 X170 Y170 G3000 ; move to the center of the bed
                      and change it to read to read, to correct the warning -
                      G0 X170 Y170 F3000 ; move to the center of the bed
                      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                      • A Former User?
                        A Former User @jumpedwithbothfeet
                        hello to all of you it's finally starting to work thank you to all of you. I have to settle because the probe often comes home before doing g32 or g29. but it works it works thank you thank you thank you you're really kingπŸ‘ πŸ‘ πŸ‘ πŸ‘
                        • A Former User?
                          thank you to all and to the groupπŸ‘ 😁
