    Euclid facility
    91
    4.7k
      A Former User
      My bed 350x350x350 and prob euclid X0 y8. 5 IMG_20220916_191317_edit_18382711277923.jpg
        M558 K0 P5 C"^io2.in" H8 F300 60 T9000 A3 S0.01
        G31 K0 P500 X-27.955 Y-18.716 Z1.033
        If you include K0, you need to use K0 everywhere else the probe is called. You only have a single probe, so remove K0 from your config where you have it.
        In your bed.g and home all you have a bunch of moves to pick the probe but then you also call the probe deploy. Your pickup moves should just be in the deploy macro.
        G1 Y8.5 F6000 ; Pick Up Klicky
        G1 X20 F2000 ;
        G1 X0 F1000 ; Pick Up Klicky
        G1 Y30 F1000 ;
        G1 Y50 F6000 ; Pick Up Klicky
        M401 ; deploy Z probe (omit if using bltouch)
          A Former User @Phaedrux
          @phaedrux ok thank you I have to change the probe control in the bed m558 and g31?
            A Former User @A Former User
            A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
              https://youtu.be/9wJ2RCimWXU
              it gives me that
                Phaedrux Moderator @A Former User
                @sgk said in Euclid facility:
                No. That's not what I meant at all. Your deploy and retract macros seem fine. You just need to call them with M401 and M402 in your bed.g and homeall.g files when you want to pick up or two away the probe. You don't need the manual G1 moves to pick it up there.
                Did you remove the K0?
                  @phaedrux k0 deleted
                    I'm really sorry I'm completely lost at this point
                      And return your deployprobe.g macro to how it was before?
                      With K0 removed, does G28, G32, and G29 function now?
                        @phaedrux
                        I deleted my deploy and retract and I didn't save
                          retractprobe.g homez.g homeall.g deployprobe.g config.g bed.g
                          πŸ‘
                          want the files in raw or it goes in ZIP
                          Good thing you uploaded them here.
                            @phaedrux yes niceπŸ‘
                              it works but not very well every time the probe feels it comes home
                                I will make a video
                                  and above all it does not balance the left and right bed
                                    https://youtu.be/Iv2z8CIwCVc
                                      jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                                      • jumpedwithbothfeetundefined
                                        jumpedwithbothfeet @A Former User
                                        @sgk Have you changed bed.g to what @Phaedrux suggested? it should now look like this -
                                        ; bed.g
                                        ; generated by Ben Levi - BLV developer as a basic version
                                        M561 												; clear any bed transform
                                        G91               									; relative positioning
                                        G1 H2 Z5 F6000   									; lift Z relative to current position
                                        G90              									; absolute positioning
                                        G28 												; home all
                                        G30 P0 X10 Y175 Z-99999 							; probe near a leadscrew, half way along Y axis
                                        G30 P1 X330 Y175 Z-99999 S2 						; probe near a leadscrew and calibrate 2 motors
                                        M402 ; retract probe (omit if using bltouch)
                                        M291 P"Leveling finished !" R"Probing.." S1 T2
                                        once you have done that go into your deployprobe.g find the line that says -
                                        G0 X170 Y170 G3000 ; move to the center of the bed
                                        and change it to read to read, to correct the warning -
                                        G0 X170 Y170 F3000 ; move to the center of the bed
                                        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                                          A Former User @jumpedwithbothfeet
                                          hello to all of you it's finally starting to work thank you to all of you. I have to settle because the probe often comes home before doing g32 or g29. but it works it works thank you thank you thank you you're really kingπŸ‘ πŸ‘ πŸ‘ πŸ‘
                                            thank you to all and to the groupπŸ‘ 😁
