    Duet wifi Randomly stops printing
    • Solid_X5undefined
      Solid_X5
      I have had this issue for a few months where the printer randomly stops! I pause and resume the print and no issue unless it stops for to long and the hot end warps where ever it happens to be and creates a divit and the print head stops at that bump and i get a layer shift. frimware is 3.4.0beta2 (2021-08-03). I performed a M119 command that I read from another user thinking I would see something that jumps out as the culprit. No! Here is the M119 command results.
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta2 (2021-08-03 12:41:37) running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996RU-N8PS0-6J9FJ-3SN6K-KSVVR
      Used output buffers: 3 of 24 (15 max)
      Static ram: 23932
      Dynamic ram: 78852 of which 16 recycled
      Never used RAM 9208, free system stack 134 words
      Tasks: NETWORK(ready,13.4%,246) HEAT(delaying,0.0%,310) Move(notifyWait,0.0%,313) MAIN(running,85.2%,441) IDLE(ready,1.4%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:01:11 ago, cause: software
      Last software reset at 2022-09-15 15:28, reason: User, GCodes spinning, available RAM 5920, slot 2
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 31.0, current 31.6, max 32.1
      Supply voltage: min 24.0, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max 0/0
      Driver 1: position 0, standstill, SG min/max 0/119
      Driver 2: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2022-09-15 15:30:17
      Cache data hit count 2518754816
      Slowest loop: 6.34ms; fastest: 0.15ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.8ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 3, maxWait 24505ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 5, completed moves 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Heater 0 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 15.93ms; fastest: 0.00ms
      HTTP sessions: 2 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.23
        WiFi MAC address ec:fa:bc:5b:47:0c
        WiFi Vcc 3.44, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 24120
        WiFi IP address 192.168.10.185
        WiFi signal strength -82dBm, mode none, reconnections 0, sleep mode modem
        Clock register ffffffff
      If anyone can shed some light, please do. Ready to solve this issue. The bed heater is seperately controlled not by Duet. I have a water cooled hot end so cooling is not controlled by the Duet.
        Phaedrux Moderator @Solid_X5
        @solid_x5 said in Duet wifi Randomly stops printing:
        3.4.0beta2
        Update your firmware. 3.4.2 was just released.
        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.2
        Upload the full zip file.
        Solid_X5undefined 1 Reply Last reply Reply Quote 0
        • Solid_X5undefined
          Solid_X5 @Phaedrux
          @phaedrux Is it a known issue on the beta release that printers randomly stop?
            jay_s_uk @Solid_X5
            @solid_x5 well you're going back quite a long time and there may well have been a bug fixed. There have also been 3 stable releases since the build you're running so there's little that can be done until you update
            Solid_X5undefined 1 Reply Last reply Reply Quote 1
            • Solid_X5undefined
              Solid_X5 @jay_s_uk
              @jay_s_uk Updated and everything seems to be working fine. Thanks for the advice sir!!
                @solid_x5 If you do run into any more issues, please capture a M122 report immediately afterwards and share your config.g and the gcode file being printed. Thanks.
