    duet wifi 1.04 USB is not detected
    Firmware installation
    • paolozampini1973undefined
      paolozampini1973
      Good evening Someone can help me I am with this problem everything worked regularly the printer was turned off for a few days I went to turn it on again and it no longer worked, the photo Shows which LEDs are on it seems that the firmware has been deleted
      connected to a computer but it is not recognized with any type of USB cable this problem was done several months ago Then the problem no longer occurred thanks
      Norderundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • Norderundefined
        Norder @paolozampini1973
        @paolozampini1973
        Is the USB cable connected directly to the computer or to a USB hub?
        Always connect directly to a computer, not to a hub.
        If the cable is connected directly... have you tried a different USB port or maybe even a different computer ?
        P.S.:
        Are you sure that the heatsinks on the driver chips are not touching any other components on the board and possibly causing a short circuit ?
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
        paolozampini1973undefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @paolozampini1973
          @paolozampini1973 Please be aware you have a 'clone' Duet 2 WiFi, not one produced by Duet3D. Heatsinks, all green LEDs, "Based on Duet2" etc.
          Try erasing the firmware fully, by putting a jumper on the 'erase' pins, then see if it shows up.
            paolozampini1973 @droftarts
            @droftarts said in duet wifi 1.04 USB is not detected:
            Yes I have already done the cancellation of signing by putting the jumper but I have not solved anything to put more it worked nothing has been touched that you give me advice the cable is directed to the computer I have changed three and they are cables that work
              paolozampini1973 @Norder
              @norder said in duet wifi 1.04 USB is not detected:
              @paolozampini1973
              P.S.:
              yes and cable is connected directly to the computer and obviously everything is disconnected as in the picture
