Solved Permantly save Z-Probe Offset after Z-Calibration via G30 S-3
After completing the z-calibration procedure I typically open "config.g" and manually adjust the z-offset by using G31.
config.g:
; BL Touch M950 S0 C"duex.pwm5" M558 P9 C"^zprobe.in" H5 F150 T6000 G31 P25 X0 Y-36 Z1.95
z-calibration (part 1):
G28 M561 G1 F3000 X240 Y160 Z20 M564 S0
z-calibration (part 2):
G92 Z0 G1 Z5 G30 S-3 M500
I was hoping M500 would save the setting in "config-override.g", but it does not.
Is there any way I can make this a permanent setting (i.e. even after restarting the machine) once I have run the script?
Thank you.
wieman01
@wieman01 you want
M500 P31
Oh, gosh, can it be that simple?! Thank you, my friend, that worked like a charm. All good now, the G31 parameter is safely stored in "config-override.g".
wieman01
@jay_s_uk said in Permantly save Z-Probe Offset after Z-Calibration via G30 S-3:
@wieman01 you want
M500 P31
How would that work with several tools? Do I add the toolnumber?
THX
Olaf -
@o_lampe you want
M500 P10
to save the tool offsets.
at least with my toolchanger that i used to run (and its the same with the E3D toolchanger) all the tools were relative to the z probe. So the z probe had no offsets and each tool was offset from that using G10
