    G-code buffer "file" overflow???
    1.5k
    • daoustundefined
      daoust
      Hi, it happen time to time on long print that the duet stop printing. The hot end and the heatbed turn down to 0 deg and the head stay at it last position. Was using sd card.
      I have 2 questions
      Is there a way to restart the print at the same position? My printer is still on and I put back the heat on the heat bed.
      What can be the cause? I take a picture of the message. It say G-code buffer "file" length overflow. Is it because I have to many file in the duet memory?
      Thank you
      Norderundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • Norderundefined
        Norder @daoust
        @daoust
        Have you adjusted the GCode-Type in your slicer ?
        In PrusaSlicer, for example, you can find this option in Printer Settings > General > GCode Type. There please RepRapFirmware.
        I think your problem might have something to do with it !?
        Sorry... German layout 😉
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
        daoustundefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @daoust
          @daoust can you grab an M122 output after that happens?
          • daoustundefined
            daoust @jay_s_uk
            @jay_s_uk I don t know what is a m122. I have leave it open so I can try it soon
              jay_s_uk @daoust
              @daoust just type M122 into the console and post the output here
                Can you also share the gcode file in question?
                • daoustundefined
                  daoust @jay_s_uk
                  • daoustundefined
                    daoust @Phaedrux
                    @Phaedrux the file is too big to share😲 😲
                    by the way, the g-code is marlin. sometime when it happen, I just restart the print and everything is fine
                    • daoustundefined
                      daoust @Norder
                      @norder I have allways use marlin firmware, maybe that can be the problem🙄
                      but the file that fail, when reprinted with the same g-code can work fine
                      Norderundefined 1 Reply Last reply Reply Quote 0
                      • Norderundefined
                        Norder @daoust
                        @daoust
                        It's happened to me before, but they weren't extremely large files.
                        The G0/G1 error I think is because the GCode is a Marlin-Type.
                        So I would switch the slicer to RepRapFirmware as the GCode-Type and slice the component again.
                        Thingiverse
                        • Norderundefined
                          Norder @Norder
                          P.S.:
                          If RepRap/Sprinter is also listed in the list of RepRapFirmware, choose RepRapFirmware.
                          RepRap/Sprinter is an obsolete GCode-Type that is no longer being worked on.
                          Thingiverse
                            Yes definitely use RepRapFirmware flavor instead of Marlin.
                            See if you can upload the file to something like dropbox or google drive and share a link that way.
                            Can you send M122 in the gcode console and copy and paste the results here?
                            daoustundefined 1 Reply Last reply Reply Quote 1
                            • daoustundefined
                              daoust @Phaedrux
                              @phaedrux I share a picture of my m122 in this post. for sharing the g-code, I can send it with wetransfer but I need a email. I don t know any other way.
                                jay_s_uk @daoust
                                @daoust you're on a super old firmware so you'd best upgrade. You won't get any support for issues with 2.02
                                Norderundefined 1 Reply Last reply Reply Quote 1
                                • Norderundefined
                                  Norder @jay_s_uk
                                  Upgrade from RRF2 to RRF3 !
                                  Please do not update to the latest firmware immediately, as this can cause problems.
                                  Please work through the following instructions.
                                  https://docs.duet3d.com/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3
                                  Excerpt from the instructions:
                                  Note: it is not possible to upgrade a Duet WiFi, Ethernet or Maestro directly from firmware 1.x or 2.x to 3.01 or later. You must upgrade to firmware 3.0 as an intermediate step.
                                  Thingiverse
                                  • Phaedruxundefined Phaedrux moved this topic from 3D Printing General Chat
                                  • daoustundefined
                                    daoust
                                    @norder I just upgrade to the new firmware by doing 3.0 first than the newer version. I redo a new configuration with the config tool while using same parameter as before.
                                    Now my z end stop is not working properlly
                                    When I try to home, the bed lift some milimeter than goes down untill colision but if I touch the Z endstop, the bed stop moving.
                                    So it look like the endstop is now inverted from N/C to N/O and vise versa. I try to install a "!" Before the zendstop. The X and Y axis work fine, only the Z axis that is not working🤔. Any I idea???
                                    Thank you
                                      dc42 administrators @daoust
                                      @daoust please post your config.g and your homing files.
                                      • daoustundefined
                                        daoust @dc42
                                        @dc42 so I was able to fix my end stop problem, it was just the rotation side of my stepper motor the problem.
                                        but here I have a small tuning to do to my config file. first, it say I have a error with heater 3, 4, 5, 6, 7... they are not found
                                        second, I have setup a heated chamber, but I would like to have acces on my panel due. is there a way to enter a g-code comande to configure a heated chamber?
                                        lastly, I have trouble with the wifi connection. is it possible that the wifi modul can be defective or it will mostly be my router that are too far. sometime it work fast and other time, it wont connect.
                                        Configuration file for Duet WiFi (firmware version 3.3)
                                        ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sun Oct 02 2022 20:41:52 GMT-0400 (Eastern Daylight Time)
                                        M550 P"createbot max" ; set printer name
                                        M552 S1 ; enable network
                                        M586 P0 S1 ; enable HTTP
                                        M586 P1 S0 ; disable FTP
                                        M586 P2 S0 ; disable Telnet
                                        M569 P2 S0 ; physical drive 2 goes forwards
                                        M92 X80.00 Y80.00 Z640.00 E430.85 ; set steps per mm
                                        M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                        M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                                        M201 X900.00 Y900.00 Z100.00 E2000.00 ; set accelerations (mm/s^2)
                                        M906 X950 Y950 Z850 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                                        M84 S30 ; Set idle timeout
                                        M208 X280 Y250 Z400 S0 ; set axis maxima
                                        M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                                        M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                        M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                        ;Z-Probe
                                        M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                        G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                        M557 X15:215 Y15:195 S20 ; define mesh grid
                                        M143 H0 S150 ; set temperature limit for heater 0 to 150C
                                        M143 H1 S350 ; set temperature limit for heater 1 to 350C
                                        M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
                                        M950 H2 C"e1heat" T2 ; create chamber heater output on e1heat and map it to sensor 2
                                        M307 H2 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
                                        M141 H2 ; map chamber to heater 2
                                        M143 H2 S100 ; set temperature limit for heater 2 to 100C
                                        M106 P1 S1 H1:2 T70 ; set fan 1 value. Thermostatic control is turned on
                                          Phaedrux Moderator @daoust
                                          @daoust said in G-code buffer "file" overflow???:
                                          Where do you see that? You only have 3 heaters defined. 0, 1, 2
                                          What firmware version is on your PanelDue? You'll likely need to update it.
                                          https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue#firmware-update-via-usb
                                          Please send M122 in the gcode console and copy and paste the results here. Perhaps your wifi module firmware didn't get up to date? Perhaps your signal strength is poor? M122 will tell us more.
                                          • daoustundefined
                                            daoust @Phaedrux
                                            @phaedrux here is the m122 for the heater and a print screen where it say that my heater 4 5 6 7 . . . Have problem
                                            Also when I activate my heated chamber, the temperature rise up to 40 deg c and the heater came in fault because the tempereture rise to slow. The chamber is big so it is normal to rise slow. How can I fix this safety? 20221010_202135.jpg
                                            For the panel due firmware update, I will try it this week. Thank you
