    Status Duet + Mosaic Palette
    PanelDue
    • maxmuellerundefined
      maxmueller
      Re: No baby stepping available during USB print
      Regarding the topic above, @nuroo mentioned he is beta testing with a Duet board the Palette 3 directly. Is there any documentation anywhere or releases? I can't find anything and
      it has been a year since then 🙂
        dc42 administrators @maxmueller
        @maxmueller it must be possible to run a Pallete with a Duet, because https://www.youtube.com/watch?v=cpV9Xk7jFOI shows a Pallete 2 being used with a SeeMeCNC Artemis printer, which uses a Duet controller. Also the machine compatibility list at https://support.mosaicmfg.com/Wiki/Palette_3_(Pro)_and_Printer_Compatibility lists several SeeMeCNC machines with Duet controllers. That page also suggests that if you have any questions regarding compatibility, you can email support@mosaicmfg.com.
        I didn't find anything on the Mosaic site that says how the Palette is connected to the printer electronics. Perhaps they expect you to connect the Pallette to the printer using a USB cable, and then it sends the job to the printer over USB, rather like Octoprint.
          Phaedrux Moderator @dc42
          @dc42 said in Status Duet + Mosaic Palette:
          This is exactly it.
          You lose a lot of Duet functionality, but it does work.
