    Solved No baby stepping available during USB print
    PanelDue
    286
    • nuroo
      nuroo last edited by T3P3Tony
      Hello All,
      I hope this is the right location for this post, if not please move.
      I'm a beta tester for Mosaic Manufacturing. With launch of one of their new products they have decided to move away from octoprint for connectivity and develop their own system. In the past the printer was connected to a pi (octoprint), now printer connects directly to palette 3.
      So I'm able to connect, disable heaters and motors, monitor temps, move z, most pronter face/printer setup type commands. Got some successful prints finished as well.
      My issue is during a print initiated by the palette 3, baby stepping is not available on printers screen. Prints not started on the palette baby stepping is available.
      It was suggested I try adding M75 (Marlin code - start print timer) but this is not a reprap command.
      Is there any thing I could add to my start gcode or a way Mosaic should be initiating prints on palette 3 that would enable baby stepping?
      Railcore2 300 zl
      Duet firmware Release 3.4.0 beta 3
      • T3P3Tony
        T3P3Tony administrators @nuroo last edited by
        @nuroo how is the palette communicating with the Duet? is it streaming gcodes over USB or uploading to the SD then printing from there?
        I assume you mean the PanelDue by the screen?
        What happens when you send M290
        with a baby step value directly:
        https://duet3d.dozuki.com/Wiki/M290
        www.duet3d.com
        nuroo 1 Reply Last reply Reply Quote 0
        • nuroo
          nuroo @T3P3Tony last edited by
          @t3p3tony
          Thank you for your response. Yes I was referring to paneldue 5in.
          Commands are streamed, sd card on duet board not used for palette 3.
          I will try issuing M290 from console while a print is active.
          • T3P3Tony
            T3P3Tony administrators @nuroo last edited by T3P3Tony
            @nuroo ok that is probably the reason, sending the gcodes over does not put the PanelDue into "printing" mode. Sending the M290 as part of the control stream over USB will work, so will sending them over the network via DWC or directly entering M290 on the console of the PanelDue.
            I have moved this to the PanelDue section and updated the title to include USB print.
            We will discuss how to indicate that a file is being printed over USB
            Its not normal to stream gcodes over USB these days. It would be good if the pallet could work with the print file on the Duet, what information does it need to know?
            www.duet3d.com
            • nuroo
              @t3p3tony said in No baby stepping available during USB print:
              That seems like the least trouble for all. What should be added to the control stream for example to make the baby stepping window available during printing?
              I was able to enter specific M290 commands while railcore was printing the Palette 3's gcode stream. The console on dwc returned "ok", when M290 commands were received. This did not however bring up the baby stepping window on the paneldue.
              • T3P3Tony
                @nuroo said in No baby stepping available during USB print:
                AFAIK there is not gcode command to change the mode to printing (other than the commands to actually start an SD print.
                @mfs12 might be good to have an option to display the babystep button even when not printing if that could be added t the settings?
                www.duet3d.com
                • mfs12
                  mfs12 last edited by
                  @nuroo, added a github issue. Any further progress will be tracked there.
                  So please refer to
                  https://github.com/Duet3D/PanelDueFirmware/issues/218
                  mfs12 created this issue in Duet3D/PanelDueFirmware
                  closed Show baby stepping button #218
                  Visit me on github at https://github.com/mfs12/
                  • nuroo
                    nuroo @mfs12 last edited by
                    @mfs12
                    Ok. Thanks for headsup. I'll keep track.
                    • mfs12
                      Will be part of next release.
