RFF 3.42 DUET WIFI 1.05+DUEX0.11
@dc42 Meanwhile, I wanted to thank her for the work she does for all of us 3D printer enthusiasts
WHY SWITCH E4STOP E5STOP E6STOP DO NOT WORK IF I CONNECT THE SAME SWITCH E0STOP E1STOP E2STOP E3STOP WORK WELL,
MY CONFIGURATION DUET 2 WIFI + DUEX 0.11 CONFIGURED IN DUEX 2 BECAUSE I HAVE EXTERNAL DRIVER DM860H AXIS E4 = X + EXTERNAL DRIVER DM860H AXIS E5 = Y config.g -
BECAUSE Switches WORK ONLY AFTER HOME AND IT IS POSSIBLE TO ENABLE THE SWITCHES ALSO SENSA DO HOME FOR MANUAL MOVEMENT ?
WHY FAN F7 DOESN'T WORK ANYMORE? THE FAN CONNECTS IT TO F8 AND IT WORKS
4)ASK HOW TO ENABLE THE FANS WHEN EN E4 = AXIS Y and ON ENABLE FAN F6 AND WHEN EN E4 and OFF DISABLE FAN F6
EN E5 AXIS = X and IN ON ENABLE FAN F5 Y AND WHEN EN E5 and IN OFF DISABLE FAN F5 AXIS Xconfig.g- FOR COOLING DUET 2 WIFI 1.05 I HAVE DETICATED ONE FAN IN FRONT OF 120MM ONE FAN FOR DUEX 0.11 OF 120MM TOTAL TWO 120MM FAN
WITHOUT PUTTING THE ALUMINUM COOLING FINS, I WANTED TO KNOW IF IT IS GOOD OR PURE AND BETTER ADD THE COOLING FINS
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S2.00 ; enable bang-bang mode for the bed heater and set PWM limit
You can not set the PWM value for the bed heater greater than S1.00
M950 F1 C"fan1" Q600 ; PWM ESTRUDER E1 WIRE BLACK WHITE create fan 1 on pin fan0 and set its frequency M106 P1 S0 H-2 ; PWM ESTRUDER E1 WIRE BLACK WHITE set fan 1 value. Thermostatic control is turned off
"H-2" parameter is wrong. It's either H-1 or H2 I guess?
@o_lampe said in RFF 3.42 DUET WIFI 1.05+DUEX0.11:
M307 H0 B1 S2.00 normally S1 You are right but for me it is S2 Because otherwise I have problems
M106 P1 S0 H-2 No this setting is correct for my configuration
@paolozampini1973 please send command M122 to the Duet and post the response here.
@dc42 said in RFF 3.42 DUET WIFI 1.05+DUEX0.11:
Thanks for answering me
console (1).txt -
@paolozampini1973 said in RFF 3.42 DUET WIFI 1.05+DUEX0.11:
console (1).txtGood morning. Let me know something please. Thank you
M106 P1 S0 H-2 No this setting is correct for my configurationBoth of those commands are invalid.
Please send M98 P"config.g" and post the response.
Your command didn't work because youhave a space between M98 P and "config.g". It must be all together.
M98 P"config.g"
What problems are you getting?
Why do you say that?
This post is deleted! -
Can you share a sliced gcode file?
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue May 04 2021 22:49:42 GMT+0200 (Ora legale dell’Europa centrale) ; General preferences G90 ; send absolute coordinates... M564 S1 H0 ; manual movement enabled H1 = forbid movement of axes , H0 allows movement of the axes , Snnn S1 = limit movement within axis boundaries, S0 = allow movement outside boundaries M83 ; ...but relative extruder moves M550 P" PAOLO ZAMPINI" ; set printer name ; Network M552 S1 ; s1 enable s0 disable network M587 S"infinity" P"cccccccc" I192.168.1.15 ; IP address M554 192.168.1.1 ; Gateway M553 255.255.255.0 ; Netmask M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 R-1 ; X FREE physical drive 0 goes forwards M569 P1 S0 R1 ; Y = Z1 physical drive 1 goes forwards M569 P2 S1 ; Z2 physical drive 2 goes forwards M569 P3 S1 ; E0 extruder 1 physical drive 3 goes forwards M569 P4 S0 ; E1 extruder 2 physical drive 4 goes forwards M569 P5 S0 ; A = DRIVER 5 nozzle nozzle 1.2 E2 physical drive 5 goes forwards M569 P6 S0 ; B = DRIVER 6 nozzle nozzle 0.4 E3 physical drive 6 goes forwards M569 P7 S0 R0 T4:4:8:8 ; E4 X external drive 7 goes forwards M569 P8 S1 R0 T4:4:8:8 ; E5 Y external drive 8 goes forwards ;M569 P9 S1 R-1 ; E6 FREE physical drive 9 goes forwards M584 X7 Y8 Z1:2 A5 B6 E3:4 S0 ; set drive mapping M671 X0:0 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis M350 X16 Y16 Z16 A16 B16 E16:16 I1 ; configure microstepping without interpolation M92 X99.975 Y99.975 Z800.10 A3200 B3200 E95.30:95.30 ; set steps per mm M566 X600.00 Y600.00 Z1400.00 A10 B10 E1500.00:1500.00 ; set maximum instantaneous speed changes (mm/min) M203 X10000.00 Y10000.00 Z3500.00 A1000 B1000 E10000.00:10000.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z1400.00 A10 B10 E3000.00:3000.00 ; set accelerations (mm/s^2) M906 X0 Y2000 Z2000 A800 B800 E1200:1200 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S10 ; Set idle timeout ; Axis Limits M208 X-25 Y10 Z0 A0 B0 S1 ; set axis minima M208 X520 Y500 Z350 A61 B61 S0 ; set axis maxima ; Endstops M574 X0 S1 P"!xstop" ; configure active-LOW endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop" ; configure active-LOW endstop for low end on Y via pin ystop M574 Z1 S1 P"!zstop+!e1stop" ; configure active-LOW endstop for low end on Z via pin null M574 B1 S1 P"!duex.e2stop" ; DRIVER 6 E0 nozzle 0.4 WIRE COLOR RED and BROWN Wire detection detection module M574 A1 S1 P"!duex.e3stop" ; DRIVER 5 E1 nozzle 1.2 WIRE COLOR WHITE and GREY Wire detection detection module ;Filament Sensing M591 P2 C"e0stop" S1 D0 ;NOZZLE 0.4 3 PIN WIRE COLOR BLACK RED YELLOW extruder 1 nozle 0.4 s1=on s0=off D = 0 or 1 or 2 or 3 Number Sensing M591 P2 C"duex.e4stop" S1 D1 ;NOZZLE 1.2 3 PIN WIRE COLOR GREEN ORANGE YELLOW extruder 2 nozle 1.2 s1=on s0=off D = 0 or 1 or 2 or 3 Number Sensing ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S2.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ;____________________________________________________________________________________________________________________________________ M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit D10= SECONDI RITARDO ERRORE M143 H1 S270 ; set temperature limit for heater 1 to 280C M570 H1 P4 T20 ; An anomaly on heater 1 must persist for 4 seconds, and must be greater or less than 20°C from the setpoint, to raise a heater fault. ;_____________________________________________________________________________________________________________________________________ M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin duex.e2temp M950 H2 C"e1heat" T2 ; create nozzle heater output on !duex.e2heat and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit D10= SECONDI RITARDO ERRORE M143 H2 S270 ; set temperature limit for heater 2 to 280C M570 H2 P4 T20 ;An anomaly on heater 2 must persist for 4 seconds, and must be greater or less than 20°C from the setpoint, to raise a heater fault. ; Fans M950 F0 C"fan0" Q600 ; PWM ESTRUDER E0 WIRE BLACK BLUE create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; PWM ESTRUDER E0 WIRE BLACK BLUE set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q600 ; PWM ESTRUDER E1 WIRE BLACK WHITE create fan 1 on pin fan0 and set its frequency M106 P1 S0 H-2 ; PWM ESTRUDER E1 WIRE BLACK WHITE set fan 1 value. Thermostatic control is turned off M950 F2 C"fan2" Q100 ; F2 FAN ESTRUDER 1.2 WIRE RED BROWEN create fan 3 on pin fan0 and set its frequency M106 P2 X0.6 T40 H2 ; F2 FAN ESTRUDER 1.2 WIRE RED BROWEN set fan 3 value. Thermostatic control is turned off M950 F3 C"duex.fan3" Q65535 ; F3 FAN ESTRUDER 0.4 WIRE RED BLACK create fan 3 on pin fan0 and set its frequency M106 P3 S1 H1 T30 ; F3 FAN ESTRUDER 0.4 WIRE RED BLACK set fan 3 value. Thermostatic control is turned off M950 F4 C"duex.fan4" Q600 ; F4 DUAL LED BED create fan 4 on pin fan0 and set its frequency M106 P4 S1 H1:2 T180 ; F4 DUAL LED BED set fan 4 value. Thermostatic control is turned off M950 F5 C"duex.fan5" Q500 ; FAN 5 X create fan 5 on pin fan1 and set its frequency M106 P5 S1 H-1 ; FAN 5 X set fan 5 value. Thermostatic control is turned on M950 F6 C"duex.fan6" Q500 ; FAN 6 Y create fan 6 on pin fan1 and set its frequency M106 P6 S1 H1:2 T20 ; FAN 6 Y set fan 6 value. Thermostatic control is turned on M950 F7 C"duex.fan7" Q65535 ; FAN 7 Duex 0.11 create fan 7 on pin fan1 and set its frequency M106 P7 S255 H-1 ; FAN 7 Duex 0.11 set fan 7 value. Thermostatic control is turned on M950 F8 C"duex.fan8" Q65535 ; FAN 8 DUET WIFI create fan 8 on pin fan1 and set its frequency M106 P8 S1 H-1;:2 T180 ; FAN 8 DUET WIFI set fan 8 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 S"nozzle 0.4 MM" ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 F1 S"nozzle 1.2 MM" ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool M302 S20 R20 ;M572 D4 SS0.025 ;nozzle 0.4 ;M572 D3 SS0.025 ;nozzle 1.2 M501 ; load saved parameters from non-volatile memory
@phaedrux thanks I solved I simply got a command wrong on the silicer
