    Replacing a Toolboard - Extruder Motor Has Never Moved
    • ArcadeKillaundefined
      ArcadeKilla
      What is warranty like? I have no successfully been able to get my Toolboard to move my extruder motor at all.
        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
        Well if you give us some more information we can try and work out what is going wrong. If it ends up being a hardware issue and it's within the warranty period we would replace it.
        ArcadeKillaundefined 1 Reply Last reply Reply Quote 0
          ArcadeKilla @Phaedrux
          @phaedrux (https://forum.duet3d.com/topic/26885/so-close-extruder-connected-to-toolboard-won-t-budge?_=1665495044262)
          As of now, no luck. Maybe I can use one of the mainboards stepper drivers to confirm the extruder drive works.
            Please share your config.g by copying and pasting the text here.
            Please also send M122 and M122 B# (where # is the canbus address of the toolboard) in the gcode console in DWC and copy and paste it here.
            How are you trying to command extrusion?
            Are you trying to extrude without the hotend being heated?
            Does your tool have a drive mapped?
            Do you have a G4 S5 command at the start of your config.g to allow time for the toolboard to startup before the config is executed?
            Yes you can use a driver on the mainboard to test the extruder.
            ArcadeKillaundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
              @Phaedrux
              I’ll find my config but when I was testing I was manually running commands to test the extruder. Even when not attached to the hotend it was not working.
                @Phaedrux
                Working on this again. Here is the last iteration of my Config.G:
                ; configuration file for Duet 3 Mini 5+ (firmware version 3.3) with Duet 3 Toolboard1LC, Rotating Magnet Filament Monitor
                M575 P1 S1 B57600                                                        ; enable support for PanelDue
                G21        ; work in millimeters
                G90        ; send absolute coordinates...
                M83        ; ...but relative extruder moves
                M550 P"duet3"                                                         	 ; set printer name
                M669 K1        ; select CoreXY mode
                ; Tool board (CAN ID #121)
                G4 S6        ; wait for tool board to start
                ; PanelDue Enable
                M575 P1 S1 B57600
                M552 S1        ; enable network
                M586 P0 S1                                                               ; enable HTTP
                M586 P1 S0                                                               ; disable FTP
                M586 P2 S0                                                               ; disable Telnet
                M569 P0.0 S0 D3                                                          ; physical drive 0.0 goes forwards use stealthChop2
                M569 P0.1 S0 D3                                                          ; physical drive 0.1 goes forwards use stealthChop2
                M569 P0.2 S0 D3                                                          ; physical drive 0.2 goes forwards use stealthChop2
                M569 P0.3 S1 D3                                                          ; physical drive 0.3 goes forwards use stealthChop2
                M569 P0.4 S1 D3                                                          ; physical drive 0.4 goes forwards use stealthChop2
                M569 P121.0 S1 D3                                                        ; physical drive 121.5 goes forwards use stealthChop2
                M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0                                       ; set drive mapping
                M350 X16 Y16 Z16 E16 I1                                                  ; configure microstepping with interpolation
                M92 X80.00 Y80.00 Z800.00 E830.00                                        ; set steps per mm
                M566 X400.00 Y400.00 Z6.00 E120.00 P1                                    ; set maximum instantaneous speed changes (mm/min)
                M203 X10800.00 Y10800.00 Z1000.00 E3600.00                               ; set maximum speeds (mm/min)
                M201 X3000.00 Y3000.00 Z100.00 E3600.00                                  ; set accelerations (mm/s^2)
                M906 X1000 Y1000 Z800 E800 I30                                           ; set motor currents (mA) and motor idle factor in percent
                M84 S30        ; Set idle timeout
                M208 X0 Y0 Z0 S1                                                         ; set axis minima
                M208 X505 Y500 Z500 S0                                                   ; set axis maxima
                M574 X1 S1 P"121.io2.in"                                                 ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io2.in on toolboard
                M574 Y2 S1 P"io6.in"                                                     ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io6.in
                M574 Z1 S2                                                               ; configure Z-probe endstop for low end on Z
                M950 S0 C"121.io0.out"                                                   ; create servo pin 0 for BLTouch on tool board
                M558 P9 C"121.io0.in" H5 F120 T6000 A5                                   ; set Z probe type to bltouch and the dive height + speeds on tool board
                G31 P500 X-40 Y-30 Z0.9                                                ; set Z probe trigger value, offset and trigger height
                M671 X-4.5:250:500 Y-4.52:500:-4.52 S5                                   ; define positions of Z leadscrews, 5mm maximum correction
                M557 X20:280 Y20:280 P5                                                  ; define 5x5 mesh grid
                ; Bed Heater
                M308 S0 Q10 P"temp0" Y"thermistor" T100000 B3950 A"Bed"                  ; configure sensor 0 as thermistor on pin temp0
                M950 H0 C"out0" T0                                                       ; create bed heater output on out1 and map it to sensor 0
                M307 H0 B0 S1.00                                                         ; disable bang-bang mode for the bed heater and set PWM limit
                M140 H0        ; map heated bed to heater 0
                M143 H0 S120                                                             ; set temperature limit for heater 0 to 120C
                																		 ; Mosquito Magnum+ Separate Heaters Single Tool (Two Sensors)
                ; Two Temperature Sensors
                M308 S1 P"temp2" Y"pt1000" A"RightTemp" 						 	 	 ;Pt1000 located in right side of hot block
                M308 S2 P"temp1" Y"pt1000" A"LeftTemp" 								 	 ;Pt1000 located in left side of hot block
                ; Define Mosquito Magnum+ heaters
                M950 H1 C"out2" T1 														 ;Single Heater
                M950 H2 C"out3" T1 														 ;Second Heater
                ; Define Monitor Temperature Sensor
                M143 H1 P1 S450 T2 A0
                M143 H2 P1 S450 T2 A0
                ;Mosquito Magnum+ Max Temperatures
                M143 H1 S450
                M143 H2 S450
                ;Tool Definition Mosquito Magnum+
                ;M563 P0 D0 H1:2 S"Mosquito Magnum+" F1 									 ;Define Mosquito Magnum+ Tool
                ;T0 																		 ;Set tool 0 as active tool
                ;G10 P0 S0:0 R0:0 														 ;Set tool operating and standby temperatures
                ;; Run Bed PID Tune!! Below is an example for a 300x300 bed
                ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0
                ;; Run Heater PID Tune!!
                ;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0
                M950 F0 C"out4" Q300													 ; create fan 0 on pin out1 on tool board and set its frequency
                M106 P0 C"Watercooling Fan" S1 H1 T45                                    ; set fan 0 value. Thermostatic control is turned on
                M950 F1 C"121.out2" Q500                                                 ; create fan 1 on pin out2 on tool board and set its frequency
                M106 P1 C"Layer Fan" S1 H-1                                              ; set fan 1 value. Thermostatic control is turned off
                M563 P0 S"Mosquito Magnum+" D0 H1:2 F1                                   ; define tool 0 with extruder drive 0 heater 1 and fan 1
                G10 P0 X0 Y0 Z0                                                          ; set tool 0 axis offsets
                G10 P0 R0 S0                                                             ; set initial tool 0 active and standby temperatures to 0C
                M302 S180 R180                                                           ; allow extrusion starting from 180C and retractions already from 180C
                ; Accelerometer
                M955 P121.0 I12                                                          ; Accelerometer on tool board, oriented counter-clockwise 90
                ; Filament Monitor
                M591 D0 P3 C"121.io1.in" S1 R70:130 L24.8 E3.0                           ; Duet3D rotating magnet sensor for extruder drive 0 is connected to io1.in on tool board,
        ; enabled, 70% to 130% tolerance, sensitivity 24.8mm.rev, 3mm detection length
                ; Custom settings
                M404 N1.75 D0.4                                                          ; set filament width and nozzle diameter
                  Phaedrux Moderator @Phaedrux
                  @Phaedrux said in Replacing a Toolboard - Extruder Motor Has Never Moved:
