Extract temp to external display
Duet Web Control
1.6k
  • undefined
    tecno @DIY-O-Sphere
    @DIY-O-Sphere
    Std 10 pin cables Exp1 to Exp1 and Exp2 to Exp2
    undefined 1 Reply Last reply 27 Oct 2022, 18:03 Reply Quote 0
    • undefined
      tecno @tecno
      Had a look again on how cables are keyed as I did not get any life at all. F-ng assembly from the chinese as turning cables 180° I now get backlight and encoder lit up but nothing on screen.
      undefined undefined 2 Replies Last reply 27 Oct 2022, 18:11 Reply Quote 0
      • undefined
        tecno @tecno
        undefined 1 Reply Last reply 27 Oct 2022, 18:13 Reply Quote 1
        • undefined
          DIY-O-Sphere @tecno
          @tecno
          As far as I can tell from the picture, turning is required for exp1 but not for exp2.
          (UTC+1)
          • undefined
            DIY-O-Sphere @tecno
            @tecno
            Perfect...
            (UTC+1)
            undefined 1 Reply Last reply 27 Oct 2022, 18:34 Reply Quote 0
            • undefined
              tecno @DIY-O-Sphere
              @DIY-O-Sphere
              So now my mini 12864 is working
              Next is to get my old RepRapDiscount to work. So how to read the silkscreen on board as regards cable keying?
              undefined 1 Reply Last reply 27 Oct 2022, 19:53 Reply Quote 0
              • undefined
                DIY-O-Sphere @tecno
                @tecno
                (UTC+1)
                undefined 1 Reply Last reply 28 Oct 2022, 08:07 Reply Quote 0
                • undefined
                  tecno @DIY-O-Sphere
                  @DIY-O-Sphere
                  I interpret the white markings as the cable keying and that is 180° yet another twisted cable, right?
                  undefined 1 Reply Last reply 28 Oct 2022, 08:16 Reply Quote 0
                  • undefined
                    dc42 administrators @tecno
                    @tecno please note, the RepRapDiscount controllers require 5V signals, so they are unlikely to work reliably with the 3.3V signals from the Duet 3 Mini. That's why we suggest the Mini 12864 display.
                    undefined 1 Reply Last reply 28 Oct 2022, 08:27 Reply Quote 0
                    • undefined
                      tecno @dc42
                      Yes I am aware of that. I assume only EXP1 needs level shifters on LCD_CS/SCK/MOSI ?
                      undefined 1 Reply Last reply 28 Oct 2022, 11:41 Reply Quote 0
                      • undefined
                        tecno @tecno
                        Lots of digging I found this:
                        https://forum.duet3d.com/post/236985
                        Looks like PCR is not here so where can I find 3pcs of this board?
                        undefined 1 Reply Last reply 29 Oct 2022, 17:34 Reply Quote 0
                        • undefined
                          tecno @tecno
                          Does anybody know if these boards are still available?
                          A bit of time wasted to CAD new board if original is to be found.
                          undefined 1 Reply Last reply 6 Dec 2022, 14:19 Reply Quote 0
                          • undefined
                            droftarts administrators @tecno
                            @tecno I think you have the BigTreeTech Mini12864 V1.0 working. Can you post your screen's config (M918 and M150)? I'll add it to the list of 'known working' screens on the wiki.
                            I've just got a Makerbase MKS Mini12864 V3.0 working with Duet 3 Mini 5+. It was supplied with the header shrouds the correct way around, which confused me, as I reversed them! It took me a while to work out what was wrong. Turning the encoder reset the display, which tipped me off, as when the cable is rotated the encoder is on the reset pin. I have the following in config.g:
                            M918 P2 E-4 C70 R4
                            M150 X2 R255 U0 B0 P255 S3 F0
                            M918 R4 is the only value that works, with C70 about right for contrast. The only odd thing now is that the red and green channel seems to be swapped; M150 R255 U0 B0 makes it green, M150 R0 U255 B0 makes it red.
                            EDIT: just worked out the encoder goes backwards, so M918 E-4 needs to be used.
                            undefined 1 Reply Last reply 6 Dec 2022, 15:09 Reply Quote 0
                            • undefined
                              tecno @droftarts
                              @droftarts
                              Hi Ian,
                              M918 P2 E2 F2000 C30 R6
                              ;M918 P2 E4 C70 R4
                              M150 X2 R255 U0 B0;
                              Either M918 works
                              Cheers
                              Bengt
