    Finish step fails for Reprap Fisher
    Config Tool
    • fotomasundefined
      fotomas
      Went trough all steps wit default settings except these settings:
      Start
      RepRapPro Fisher
      General
      Board: Duet2WiFi
      Firmware Version: 3.3 or later (stable)
      Network
      WiFi Access Point Name ...
      WiFi Password ...
      Finish
      Unchecked DWC firmware and latest stable firmware
      Error in browser console:
      vue.runtime.esm.js:3020
      TypeError: Cannot read properties of null (reading 'output_pin')
          at Template.js:410:37
          at Array.forEach (<anonymous>)
          at Object.validatePins (Template.js:409:20)
          at a.goToNextPage (App.vue:182:1)
          at click (App.vue:1:2431)
          at Ln (vue.runtime.esm.js:2988:30)
          at n (vue.runtime.esm.js:1786:20)
          at link.js:181:19
          at a.onClick (link.js:180:12)
        droftarts administrators @fotomas
        @fotomas What version of RRF did you update from? Did you update DWC as well? Generally, you need to run the same version of DWC as RRF. There's also not much reason to run RRF 3.3; update to the latest, ie v3.4.3. Then follow the instructions here, or adapt them for 3.3 if you want to run that: https://forum.duet3d.com/post/296989
        fotomasundefined 1 Reply Last reply Reply Quote 0
        • fotomasundefined
          fotomas @droftarts
          @droftarts I think you misunderstood. This is regarding the configtool, in the configuration tool forum.
          /Tomas
          droftartsundefined 2 Replies Last reply Reply Quote 0
            @fotomas Oops, sorry! One for @chrishamm
              @fotomas I think it's to do with the Z endstop. For some reason can't select 'Switch'.
              Edit: ... and the I/O mapping page isn't showing up correctly. I think there's an incompatibility in the Fisher config template.
