    Phase A and B may be disconnected
    driver error help
    • Rodrigue Richallandundefined
      Rodrigue Richalland
      Hi i have problem with my 3D printer Core XY .
      My 3D printer working well 2 day ago but now when i start to move X or Y axies i have error "Warning : Driver 1 warning : Phase A and B may be disconnected"unknown.png.
      Sometime i have "Error: Driver 1 error: over temperature shutdown" error but driver is cold.
      I has check all wire and connection with multimeter all is good so i have try to switch betwen X and Y connector for try step motor and same error always on driver 1.
      So I need you help! 🙂
      ps: I send below the M122 diagnostic of printer
      thanks in advance
      Rodrigue
      diagnostic.txt
        Is this a new build or has it been running for some time?
        Has anything changed recently or happened to perhaps cause damage?
        When and where did you purchase the Duet?
        Rodrigue Richallandundefined 1 Reply Last reply Reply Quote 0
          Rodrigue Richalland @Phaedrux
          @Phaedrux said in Phase A and B may be disconnected:
          It's my own 3D printer. I've purchase the duet on e3D online one year ago. I've do somes modifications recently on wiring to duex 5 attached to the duet 2.On duex 5, i've got a problem with pw5 outpout. Maybe the transistor 5 is broken. I dont know if this issue can damage the duet 2 as well.
          Thanks for your time !
          Rodrigue
            Can you post some photos of the board especially the driver chip that isn't working?
              @Phaedrux
              a electronic engeneer has come to check the issue. Somebody have the PCB diagram of DUET2 wifi & DUEX5. We will try to replace the TMC drive that dont work.
                You can find some hardware source here: https://github.com/Duet3D/Duet-2-Hardware
