    Fan settings not working properly with sliders
    • skhotsoundefined
      skhotso
      I sincerely apologize in advance for this stupid question but I cannot seem to get my print cooling fan set up.
      When I repurposed my 3d printer for production work I was printing with PETG and didn't need a cooling fan anymore so I took it out. Now it is being repurposed for general use and cannot get it to operate anymore.
      I previously had a fan on fan0 pins to cool the drivers and an led strip on fan2 pins. I added a print cooling fan to fan1 pins and adjusted the config accordingly.
      The fan0 is(or was) set to turn on when the mcu temp got to 45C. I haven't noticed it spinning up anymore.
      In DWC, I see "tool fan", "fan 1", and "fan 2" listed on the status window. I can turn on the led strip but moving "tool fan" or "fan 1" slider does nothing except the sliders move together. I think they move together because I assigned fan 1 to the tool.
      Is there something that I'm missing here?
      M950 F0 C"fan0" Q250
      ;M106 P0 S0 H-1
      M950 F1 C"fan1" Q250
      M106 P1 S0 H-1
      M950 F2 C"fan2" Q500
      M106 P2 S0 H-1
      M308 S4 Y"mcu-temp" A"MCU"   ; configure sensor  as thermistor on pin e1temp for left stepper
      M106 P0 H4 L0.0 X1 B0.5 T45:55      ; set fan 0 value, turn on at 50% if the CPU temperature reaches 45C, and increase to full speed gradually as the temperature rises to 55C
      M563 P0 D0 H1 F1                                   ; define tool 0
        Have you tested that fan on an allways-on fan port to see if it's actually working at all?
        Have you tried a different fan on the fan1 port to see if it's the port that's not working?
        The gcode looks correct.
        skhotsoundefined 1 Reply Last reply Reply Quote 0
        • skhotsoundefined
          skhotso @Phaedrux
          @Phaedrux
          Yep.. I forgot to try that troubleshooting step before posting. I just made the assumption that the red lead on the fan would go to vfan and black lead would go to fan-.
          After your response, I was like duh. went to test it on the always on port and it didn't work, swapped pins and it worked.
          this thread can be closed and deleted from existence.
          • T3P3Tonyundefined T3P3Tony marked this topic as a question
          • T3P3Tonyundefined T3P3Tony has marked this topic as solved
