    G32 Error: Probe was not triggered during probing move
    STM
    1.1k
    • john345463563undefined
      john345463563
      Hi All,
      I'm a real newbie on 3d printers and RepRap.
      I am trying to setup a BLTouch on and ender3 and I get this error when the extruder is about to touch the bed:
      ; bed.g
      G29  ; probe the bed and enable compensatio
      ; homez.g
      G91               ; relative positioning
      G1 H2 Z5 F6000    ; lift Z relative to current position
      G1 H1 Z-255 F1800 ; move Z down until the endstop is triggered
      G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
      ; homeall.g
      ; called to home all axes
      G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000       ; go back a few mm
      G1 H1 X-240 Y-240 F360  ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z-255 F360        ; move Z down stopping at the endstop
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M552 S0
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S0                                     ; physical drive 0 goes forwards using default driver timings
      M569 P1 S0                                     ; physical drive 1 goes forwards using default driver timings
      M569 P2 S1                                     ; physical drive 2 goes forwards using default driver timings
      M569 P3 S0                                     ; physical drive 3 goes forwards using default driver timings
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z600.00 E1200.00     ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
      M906 X580 Y580 Z580 E650 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X230 Y230 Z250 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
      ;M591 D0 P7 C"e0stop" S1  R50:130 L7.0 E10     ; BTT Smart Filament Sensor
      ;M591 D0 P1 S1                                 ; Filament runout Sensor
      ; Z-Probe  Bltouch
      ;M950 S0 C"servo0"                              ; create servo pin 0 for BLTouch
      ;M558 P9 C"^probe" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
      ;G31 P500 X-40 Y-10 Z2.95                      ; set Z probe trigger value, offset and trigger height
      ;M557 X10:180 Y10:210 S40                       ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
      M301 P21.73 I1.54 D76.55                       ; disable bang-bang mode for the bed heater and set PWM limit
      ;M307 H0 R2 D65 B1 S1.00                        ; disable bang-bang mode for the bed heater and set PWM limit
      M307 H0 A0.425 C0.506 D2.82 S0.50 V0.0 B0       ;   NEW
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S150                                   ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                   ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q1000                          ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q1000                          ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H1 T60                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      ;M575 P1 S1 B57600                              ; enable support for PanelDue
      M575 P1 S2 B57600
      M552 S1                                        ; enable network
      M150 X2
      T0 P0
      ; jp
      M918 P1 E4 F1000000
      ; BlTouch
      M558 P9 H5 F120 T6000 C"^probe"
      ; Setup Servo0 as servo port on SKR-RRF-E3
      M950 S0 C"Servo0"
      G31 P550 X-40 Y-5 Z2.05
      ; Filament Sensor
      M591 D0 P1 S1
      • OwenDundefined
        OwenD
        You need to use G30 to home your Z axis.
        Replace these lines in your homez.g and homeall.g
        with
        G30
        john345463563undefined 1 Reply Last reply Reply Quote 1
          john345463563 @OwenD
          @OwenD
          I'm trying different G30 configuration but the head will go on the home position and hit multiple time the z switch and it will error again.
          tried:
          G30;
          G30 X50 Y50;
          ; homez.g
          ; called to home the Z axis
          ;jp; G1 H1 Z-255 F1800 ; move Z down until the endstop is triggered
          G30 X50 Y50;JP ADDED
          ;G91              ; relative positioning
          ;G1 Z5 F100       ; lift Z relative to current position
          ;G90              ;   absolute positioning
          ; homeall.g
          ;jp; G1 H1 Z-255 F360        ; move Z down stopping at the endstop
          G30 X50 Y50 ; JP ADDED
            Phaedrux Moderator @john345463563
            @john345463563 said in G32 Error: Probe was not triggered during probing move:
            G30 X50 Y50;
            That won't work. You need to position the probe first with a G1 X50 Y50 first.
              john345463563 @Phaedrux
              @Phaedrux
              Tried that but its still hitting the z switch
              https://www.veed.io/view/2662d068-d4fd-4333-b377-a7714f70bd2a
              john345463563undefined 1 Reply Last reply Reply Quote 0
                john345463563 @john345463563
                This is my homez and homeall, however
                when I click homez I get: Error: Insufficient axes homed for bed probing
                When I click homeall I get: G32 Error: Probe was not triggered during probing move
                This is what happens in both case: https://www.veed.io/view/2662d068-d4fd-4333-b377-a7714f70bd2a
                homez.g
                ;JP REMOVED; G1 H1 Z-255 F1800 ; move Z down until the endstop is triggered
                G31 X50 Y50  ;JP ADDED
                G30 X50 Y50  ;JP ADDED
                homeall.g
                ;JP COMMENTED  G1 H1 Z-255 F360        ; move Z down stopping at the endstop
                G31 X50 Y50      ; JP ADDED
                BlTouch
                M918 P1 E4 F1000000
                M950 S0 C"Servo0"
                  M558 P9 H5 F120 T6000 C"^probe" M950 S0 C"Servo0"
                  Where did you get those?
                  Can you send M122 and M98 P"config.g" in the gcode console in DWC and copy and paste the results here?
                  Homez gives you an error like that if the X and Y axis aren't homed yet.
                  G31 X50 Y50 ;JP ADDEDG30 X50 Y50 ;JP ADDEDG92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                  this is all still incorrect.
                  Here's an example of what it should be
                  homeall.g
                  G1 X150 Y150 F6000      ; move to bed center
                  G30  ; probe z
                  And here is an example of what the bltouch config should look like
                  M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                  M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
                  M557 X15:215 Y15:195 S20                       ; define mesh grid
                    @Phaedrux
                    Thank you so much for your help!
                    I'm doing some progress, now the extruder will move in the middle on the bed but then I get this error:
                    Error: Invalid Z probe index
                    Error: in file macro line 8: G30: Z probe 0 not found
                    and
                    Error: in file macro line 11: G30: Z probe 0 not found
                      Did you also fix up the bltouch config in your config.g?
                        @Phaedrux
                        M122 returns but M98 P"config.g" erros and the connection is reseted, I am using a BLtouch clone.
                        >>> m122
                        SENDING:M122
                        RepRapFirmware for STM32F4 based Boards (biquskr_rrf_e3_1.1) version 3.4.2_101 (2022-09-14 11:00:21) running on STM32F4
                        Board ID: 21064-0N0JA-JJ5T4-7S18N-GBQS7-40000
                        Used output buffers: 1 of 40 (23 max)
                        Static ram: 19520
                        Dynamic ram: 84372 of which 648 recycled
                        Never used RAM 25504, free system stack 161 words
                        CCMRam static ram: 16760 dynamic ram: 19708 free ram 29064
                        Tasks: NETWORK(ready,11.9%,242) HEAT(notifyWait,0.0%,347) Move(notifyWait,0.0%,361) TMC22xx(delaying,1.7%,135) FSWRITE(notifyWait,0.0%,566) MAIN(running,86.4%,436) IDLE(ready,0.0%,29), total 100.0%
                        Owned mutexes: WiFi(NETWORK) BITIO(TMC22xx) USB(MAIN)
                        Last reset 00:14:34 ago, cause: power on/off
                        Last software reset at 2022-11-06 13:21, reason: User, GCodes spinning, available RAM 27092, slot 1
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00454000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                        Error status: 0x00
                        [ERROR] Error status: 0x00
                        Aux0 errors 0,0,0
                        Step timer max interval 0
                        MCU temperature: min 40.8, current 43.6, max 43.6
                        Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                        Events: 0 queued, 0 completed
                        Driver 0: standstill 2209, SG min 0, reads 49289, writes 8
                        Driver 1: standstill 2209, SG min 0, reads 49289, writes 8
                        Driver 2: standstill 2209, SG min 0, reads 49289, writes 8
                        Driver 3: standstill 2209, SG min 0, reads 49290, writes 8
                        Driver 4:
                        Driver 5:
                        Driver 6:
                        Driver 7:
                        Driver 8:
                        Driver 9:
                        Driver 10:
                        Driver 11:
                        Driver 12:
                        Driver 13:
                        Date/time: 2022-11-07 15:32:21
                        Slowest loop: 162.98ms; fastest: 0.09ms
                        === Storage ===
                        Free file entries: 10
                        SD card 0 detected
                        SD card longest read time 1.2ms, write time 0.0ms, max retries 0
                        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                        === MainDDARing ===
                        === AuxDDARing ===
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is ready with "M122" in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty
                        === Network ===
                        Slowest loop: 20.75ms; fastest: 0.00ms
                        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0)
                        HTTP sessions: 2 of 8
                        Uploads/Errors: 0/0
                        = WiFi =
                        Network state is active
                        Bad header: 0/0
                        WiFi firmware version 1.25B0-01S-D
                        WiFi MAC address 62:22:32:1d:82:4d
                        WiFi Vcc 3.38, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 35192
                        WiFi IP address 192.168.20.121
                        WiFi signal strength -68dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00004002
                        >>> M98 P"config.g"
                        SENDING:M98 P"CONFIG.G"
                        HTTP is enabled on port 80
                        FTP is disabled
                        TELNET is disabled
                        Error: bad model parameters
                        [ERROR] Error: bad model parameters
                        Led port is 0
                        Pin is already allocated as pwm 48
                        WiFi module is idle
                        Error: Unknown pin name 'exp.heater3'
                        [ERROR] Error: Unknown pin name 'exp.heater3'
                        Error: Unknown pin name 'zprobe.in'
                        [ERROR] Error: Unknown pin name 'zprobe.in'
                        [ERROR] Error: Invalid Z probe index
                        Error: in file macro line 105: M591: missing parameter 'C'
                        [ERROR] Error: in file macro line 105: M591: missing parameter 'C'
                        • Phaedruxundefined Phaedrux moved this topic from General Discussion
                          You didn't mention it was an STM based board. I don't know what the correct pin names for that board would be. But once you find them, it should work once you put them into bltouch probe config. Don't forget to also setup the Deployprobe.g and Retractprobe.g macros in the sys folder.
                            jay_s_uk @john345463563
                            @john345463563 pin names are here
                            https://teamgloomy.github.io/skr_rrf_e3_pins.html
                              john345463563 @jay_s_uk
                              @jay_s_uk
                              I think this is the Out of the Box pin configuration, however this was not working, I believe:
                              ; BlTouch
                              M950 S0 C"Servo0"
                                @john345463563 yep, that looks right https://teamgloomy.github.io/skr_rrf_e3_bltouch.html
                                so i would suggest rechecking your wiring
                                  @jay_s_uk
                                  with the OOB config the z will hit multiple time on the Z switch when home all:
                                  https://www.veed.io/view/30b310ca-1c11-4b33-a064-c4d5c6d43daf?panel=share
                                  ; BlTouch
                                  M950 S0 C"Servo0"
                                  homeall.g
                                  G91
                                  G1 H2 Z5 F6000
                                  G1 H2 X5 Y5 F6000
                                  G90
                                  G1 X150 Y150 F6000
                                  G30
                                    You'll need to physically alter the placement of the BLtouch to lower it down a bit and probably move the z endstop out of the way. The bottom of the BLtouch body should be ~8mm above the nozzle tip to allow for proper trigger height.
                                      If you raise the print head higher up and then do a homeall can you touch the pin with your finger to see if it stops z motion correctly?
                                        @Phaedrux
                                        Yeah! thats one part of problem if I touch the pin while homing it will not stop the motor check the video:
                                        https://www.veed.io/view/47fba682-59b9-4054-8d5c-fa732df8e43f?panel=share
                                        the BLTouch wil changing color and at the end it will become red
                                          Check the continuity of the signal wire. That's usually the white one that would be going to the "probe" input pin.
                                            john345463563
                                            Thank you so much! @Phaedrux
                                            Great Call! i've inverted 3dTouch white and black wire and now the sensor works.
                                            Now I am Following this:
                                            https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing
                                            I send these commands:
                                            • M561
                                            • M564 S0
                                            • G92 Z0
                                            • G30 S-1 Stopped at height 1.510 mm
                                            • edited in congif.g
                                              ---> G31 P550 X-40 Y-5 Z1.51
                                            • Reboted
                                            Now I will like to level the bed and print, i am
                                            • homing X (not configured for BLtouch)
                                            • homing Y (not configured for BLtouch)
                                            • HomeAll (not sure why the home is in the middle of the bed)
                                            • True Bed leveling G32 (should I use this or the other?)
                                            • Print
                                            I am wondering:
                                            1. Is that the correct way of leveling?
                                            2. is there something wrong in my configuration?
                                            3. I am also wondering why the homeAll is going in the middle?
                                            4. should I edit also the homeX, homeY, HomeZ?
                                            5. Is there any video/tutorial/info on how to level the bed?
                                            homeall.g
                                            G91
                                            G1 H2 Z5 F6000
                                            G1 H2 X5 Y5 F6000
                                            G90  ; JP ADDED
                                            G1 X150 Y150 ; JP ADDED
                                            G30   ; JP ADDED
                                            HomeX,Y,Z
                                            ; homex.g   HomeX
                                            G1 H1 X-240 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                            G1 H2 X5 F6000    ; go back a few mm
                                            G1 H1 X-240 F360  ; move slowly to X axis endstop once more (second pass)
                                            G1 H2 Z-5 F6000   ; lower Z again
                                            G90               ; absolute positioning; homex.g
                                            ; homey.g  HomeY
                                            G1 H1 Y-240 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                            G1 H2 Y5 F6000    ; go back a few mm
                                            G1 H1 Y-240 F360  ; move slowly to Y axis endstop once more (second pass)
                                            ; homez.g   HomeZ
                                            config.g
                                            M950 S0 C"Servo0"
                                            M557 X50:180 Y50:210 S40
                                            config-override.g
                                            ; config-override.g file generated in response to M500 at 2021-01-20 10:10
                                            ; Heater model parameters
                                            M307 H0 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0
                                            M307 H1 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0
                                            ; Workplace coordinates
                                            G10 L2 P1 X0.00 Y0.00 Z0.00
                                            G10 L2 P2 X0.00 Y0.00 Z0.00
                                            G10 L2 P3 X0.00 Y0.00 Z0.00
                                            G10 L2 P4 X0.00 Y0.00 Z0.00
                                            G10 L2 P5 X0.00 Y0.00 Z0.00
                                            G10 L2 P6 X0.00 Y0.00 Z0.00
                                            G10 L2 P7 X0.00 Y0.00 Z0.00
                                            G10 L2 P8 X0.00 Y0.00 Z0.00
                                            G10 L2 P9 X0.00 Y0.00 Z0.00
                                            M486 T0M486 S-1
