    Driver out of range - DUET3 with 1XD
    • dselaundefined
      dsela
      I'm trying to run my extruder with an external stepper driver (2DM2280) controlled with the 1XD expansion board (wired according to "Differential connection"). Currently I can't get the motor to turn.
      I've set the 1XD CAN address to 40 and tested communications:
      M115 B40
      Duet EXP1XD firmware version 3.4.4 (2022-10-14 11:45:39)
      M122 B40
      Diagnostics for board 40:
      Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
      All averaging filters OK
      Never used RAM 5556, free system stack 88 words
      Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.1%,109) CanAsync(notifyWait,0.0%,64) CanRecv(notifyWait,0.0%,77) CanClock(notifyWait,0.0%,64) MAIN(running,96.5%,448) IDLE(ready,0.0%,40) AIN(delaying,3.4%,142), total 100.0%
      Last reset 00:02:20 ago, cause: software
      Last software reset data not available
      Driver 0: pos 0, 80.0 steps/mm, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 1/4, peak Rx sync delay 200, resyncs 0/0, no step interrupt scheduled
      VIN voltage: min 26.5, current 26.5, max 26.5
      MCU temperature: min 22.0C, current 22.6C, max 22.8C
      Last sensors broadcast 0x00000000 found 0 115 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 1146, send timeouts 4, received 1219, lost 0, free buffers 37, min 37, error reg 110000
      Last cancelled message type 4525 dest 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
      This is my config.g:
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.12 on Fri Aug 05 2022 12:05:46 GMT+0300 (Israel Daylight Time)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"K6"                                   ; set printer name
      G4 S2 ; wait for expansion boards to start
      M552 P192.168.2.3 S1                             ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0.2 S0                                 ; physical drive 0.2 goes forwards
      M569 P0.0 S0                                 ; physical drive 0.0 goes forwards
      M569 P0.1 S1
      M569 P0.3 S0                                 ; physical drive 0.3 goes forwards
      M569 P40 S1 R1                                 ; physical drive 0.4 goes forwards
      M569 P40 T20:20:20:20
      M584 X0.2 Y0.0:0.1 Z0.3 E40                    ; set drive mapping
      M350 X8 Y16 Z16 I1                                  ; configure microstepping with interpolation
      M92 X320.00 Y132.84 Z640.00 E420.00             ; set steps per mm
      M566 X30 Y200 Z30 E50.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X180 Y1800 Z180 E120.00      ; set maximum speeds (mm/min)
      M201 X20.00 Y120.00 Z20.00 E25.00         ; set accelerations (mm/s^2)
      M906 X2500 Y4000 Z2500 I30              ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X300 Y210 Z50 S0                        ; set axis maxima
      M574 X1 S1 P"io3.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io0.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
      M574 Z1 S1 P"io4.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io3.in
      M558 P0 H0 F120 T1200                        ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                     ; define mesh grid
      M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H1 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
      M307 H1 B1 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H1                                      ; map heated bed to heater 0
      M143 H1 S120                                 ; set temperature limit for heater 0 to 120C
      ;M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M308 S0 P"spi.cs1" Y"thermocouple-max31856";
      M950 H0 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
      M307 H0 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H0 S280                                 ; set temperature limit for heater 1 to 280C
      M950 F0 C"out4" Q500                         ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out5" Q500                         ; create fan 1 on pin out5 and set its frequency
      M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D40 H0 F0                             ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      T0
      And these are the errors I get:
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Error: Driver number 40 out of range
      Error: bad drive number
      Error: in file macro line 69: G10: Invalid tool number
      Error: in file macro line 70: G10: Invalid tool number
      I've updated to the latest firmware (3.4.4 zip bundle)
      When I try to run the extruder (for example G1 E1) I make sure to allow cold extrusion (M302 P1).
      Any help would be greatly appreciated.
      Thanks
        dc42 administrators @dsela
        @dsela
        That should be E40.0 i.e. board 40 driver 0. Same for the P parameter in the M569 commands.
        • dselaundefined
          dsela
          @dsela said in Driver out of range - DUET3 with 1XD:
          Thanks.. I changed everywhere to E40.0 (Also in tools section). I still get these errors:
          M98 P"config.g"
          FTP is disabled
          TELNET is disabled
          Updated config.g file:
          M569 P0.1 S1
          M569 P40.0 S1 R1                             ; physical drive 0.4 goes forwards
          M569 P40.0 T20:20:20:20
          M584 X0.2 Y0.0:0.1 Z0.3 E40.0                  ; set drive mapping
          M563 P0 D40.0 H0 F0                           ; define tool 0
          T0
          • dselaundefined
            dsela
            Update - After I saw another post on the matter I've changed the M563 to D0 (instead of D40.0). Now I get no errors and the motor turns.
            Thanks a lot!
            • dc42undefined dc42 marked this topic as a question
