    Printing speed just slow motion
    Using Duet Controllers
    451
    • axiomundefined
      axiom
      In the slicer (Cura) I set a print speed of 30 mm/s. However, the printer printed in absolute slow motion. What can be the reason?
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @axiom
        @axiom
        You're going to have to post your config.g file so people can look at your settings.
        Also, it's helpful to post the output from the Diagnose command M122
          I would guess that the printer profile you are using has some speed commands for marlin in the start gcode that is setting the speed to a lower minimum than you have in config.g
          Check your slicer start gcode and remove any speed commands and make sure it's set to RepRap gcode flavor.
          axiomundefined 2 Replies Last reply Reply Quote 0
          • axiomundefined
            axiom @Phaedrux
            This post is deleted!
            • axiomundefined
              axiom @Phaedrux
              @Phaedrux
              Hi, here is my starting g-code. Which of these should I delete?
              M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
              M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
              M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
              M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
              M220 S100 ;Reset Feedrate
              M221 S100 ;Reset Flowrate
              Many greetings,
              Don
                dc42 administrators @axiom
                @axiom delete the M201 and M203 lines.
                  I'd delete these as well
                  axiomundefined 1 Reply Last reply Reply Quote 0
                  • axiomundefined
                    axiom @Phaedrux
                    @Phaedrux
                    I deleted all 4 lines... and what can I say... amazing speed!!
                    Thank you both
                    Many greetings,
                    Don
                    PS: New puzzles are just appearing again (progress display and filament consumption...but first the printer is running and I can devote myself to the insulation and construction space closure)
