    Time/ Date setting
    • hauschkaundefined
      hauschka
      I'm using the Duet3 in an SBC config.
      I'm trying to set the time/date, via the M905 command.
      when querying the printer about the time/date straight afterwards, it still thinks it's in 2020.
      Any ideas on how to solve this?
      • hauschkaundefined
        hauschka
        This is the current firmware that's on the device:
        Board: Duet 3 MB6HC (MB6HC)
        DSF Version: 3.1.1
        Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2)
        I understand there are updates available, however we're aiming to keep this device at that firmware for compatibility with a deployed device
        Any ideas?
          jay_s_uk @hauschka
          @hauschka SBC mode in 3.1.1 wasn't great duw processing stuff out of sync etc. If I were you I wouldn't bother as this won't be the only issue you have
