    while loop doesn't end
    Gcode meta commands
    828
    • mherundefined
      mher
      Hi all,
      I'm having a bit of a strange issue.
      I'm trying to run a while loop a x number of times by checking the iterations
      I'm doing this by calling
      while iterations < 4
      I would expect the while loop to break after the 4th iteration. However the while loop keeps running indefinitely.
      If I add an if check inside the while loop to break it it does work.
      while iterations < 3
          if iterations > 3
              break
      The entire script (which is to calibrate the probe, by using a klicky probe) is here;
      ;Calibrate Klicky probe
      ; if two speed probing is configured in M558,we probably want to reduce the speed for this test
      var ProbeSpeedHigh = sensors.probes[0].speeds[0]*60 ; Speeds are saved in mm/sec in the object model but M558 uses mm/min
      var ProbeSpeedLow = sensors.probes[0].speeds[1]*60
      var centerX = {(move.axes[0].min + move.axes[0].max)/2} ; Set the center X to a variable to use later
      var centerY = {(move.axes[1].min + move.axes[1].max)/2} ; set the center Y to a variable to use later
      var originalDiveHeight = sensors.probes[0].diveHeight	; Set the original dive height to a variable before changing it
      M558 H2 F60 ; reduce probe speed to 60mm/min for accuracy - adjust F parameter as required. Change the dive height to make room for probing
      ;define some variables to store readings
      var NumTests=10 ; modify this value to define number of tests
      ; Do not change below this line
      var RunningTotal=0
      var Average=0
      var Lowest=0
      var Highest=0
      ; If the printer hasn't been homed, home it
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
        G28
      else
      	G1 Z{sensors.probes[0].diveHeight} F360 ; if axes homed move to dive height
      M290 R0 S0 ; clear babystepping
      ;ensure you have room for the probe
      if move.axes[2].machinePosition < sensors.probes[0].diveHeight
      ; move nozzle to centre of bed
      G1 X{var.centerX} Y{var.centerY} F99999
      M564 S0 H0 ; Allow movement beyond limits
      ; Jog head to position
      M291 P"Jog nozzle to touch bed" R"Set nozzle to zero" S3 Z1
      G92 Z0 ; set Z position to zero
      M291 P"Press OK to begin" R"Ready?" S3;
      G91 G1 H2 Z3 G90					; Set to relative positioning, move Z up 3mm, change back to absolute positioning
      M98 P"/macros/ZProbe/klicky_load.g"	; Make sure the klicky probe is loaded
      ; Move probe over top of same point that nozzle was when zero was set
      G1 X{var.centerX - sensors.probes[0].offsets[0]} Y{var.centerY - sensors.probes[0].offsets[1]} F99999
      G1 Z{sensors.probes[0].diveHeight}; lift head
      echo "Current probe offset = " ^ sensors.probes[0].triggerHeight ^ "mm"
      ; carry out 10 probes (or what is set in NumTests variable)
      while iterations < var.NumTests
      	G1 Z{sensors.probes[0].diveHeight} 		; move to dive height
      	G30 S-1
      	M118 P2 S{"Test # " ^ (iterations+1) ^ " Triggered @ " ^ move.axes[2].machinePosition ^ "mm"} ; send trigger height to Paneldue console
      	M118 P3 S{"Test # " ^ (iterations+1) ^ " Triggered @ " ^ move.axes[2].machinePosition ^ "mm"} ; send trigger height to DWC console
      	if iterations == 0
      		set var.Lowest={move.axes[2].machinePosition} ; set the new lowest reading to first probe height
      		set var.Highest={move.axes[2].machinePosition} ; set the new highest reading to first probe height
      	if move.axes[2].machinePosition < var.Lowest
      		G4 S0.3
      	if move.axes[2].machinePosition > var.Highest
      		G4 S0.3
      	set var.RunningTotal={var.RunningTotal + move.axes[2].machinePosition} ; set new running total
      	G4 S0.5
      set var.Average = {(var.RunningTotal - var.Highest - var.Lowest) / (var.NumTests - 2)} 	; calculate the average after discarding th ehigh & low reading
      ;M118 P3 S{"running total = " ^ var.RunningTotal} ; send running total to DWC console
      ;M118 P3 S{"low reading = " ^ var.Lowest} ; send low reading to DWC console
      ;M118 P3 S{"high reading = " ^ var.Highest} ; send high reading to DWC console
      M118 P2 S{"Average excluding high and low reading = " ^ var.Average} ; send average to PanelDue console
      M118 P3 S{"Average excluding high and low reading = " ^ var.Average} ; send average to DWC console
      G31 P500 Z{var.Average} ; set Z probe offset to the average reading
      M564 S0 H1 ; Reset limits
      M558 F{var.ProbeSpeedHigh}:{var.ProbeSpeedLow} ; reset probe speed to original
      G1 Z{sensors.probes[0].diveHeight} F360 ; move head back to dive height
      M98 P"/macros/ZProbe/klicky_unload.g"	; Make sure the klicky probe is unloaded
      M291 P{"Trigger height set to : " ^ sensors.probes[0].triggerHeight  ^ " OK to save to config-overide.g, cancel to use until next restart"} R"Finished" S3
      M500 P31 ; optionally save result to config-overide.g
      OwenDundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @mher
        @mher said in while loop doesn't end:
        You should only need to set this variable to var NumTests=4 if you only want four tests
        Also your indenting here isn't uniform
          G28
        else
        mherundefined 1 Reply Last reply Reply Quote 0
        • mherundefined
          mher @OwenD
          @OwenD
          Yeah i was just using the 4 as an example. the thing is it just keeps going in the while loop wayyy past 10. Fixing the indentation doesn't change anything either
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @mher
            @mher
            I suspect your calls to the macros that attach/detach may be causing some problems.
            You may need to post those.
            If I comment those out (and lower some of the G1 speeds to suit my system) I get
            var RunningTotal=0
            var Average=0
            var Lowest=0
            var Highest=0
            	G28
            else
            G1 X{var.centerX} Y{var.centerY} F1300
            ;G91 G1 H2 Z3 G90					; Set to relative positioning, move Z up 3mm, change back to absolute positioning
            ;M98 P"/macros/ZProbe/klicky_load.g"	; Make sure the klicky probe is loaded
            G1 X{var.centerX - sensors.probes[0].offsets[0]} Y{var.centerY - sensors.probes[0].offsets[1]} F1300
            	G1 Z{sensors.probes[0].diveHeight + 5} 		; move to dive height
            	M400
            	G30 S-1
            	if iterations == 0
            		G4 S0.3
            		G4 S0.3
            	G4 S0.5
            ;M98 P"/macros/ZProbe/klicky_unload.g"	; Make sure the klicky probe is unloaded
            ;M291 P{"Trigger height set to : " ^ sensors.probes[0].triggerHeight  ^ " OK to save to config-overide.g, cancel to use until next restart"} R"Finished" S3
            ;M500 P31 ; optionally save result to config-overide.g
            mherundefined 1 Reply Last reply Reply Quote 1
            • mherundefined
              mher @OwenD
              @OwenD
              could very well be I've only just started installing the klicky probe and making the required changes to the firmware.
              here is my load macros:
              ; Move to load the klicky onto the eva tool
              M98 P"/macros/ZProbe/Klicky/klicky_status.g" ; Check the probe's current status
              ; Check if the status for klicky is already attached
              if global.klicky_status != "attached"
              	M98 P"/macros/Predefined Locations/klicky_location.g" 	; Move to pick up the probe
              	G91														; Switch to relative positioning
              	G1 X-60 F99999											; Move X to 0
              	G1 X60 F99999											; Move X to 60
              	G90														; Switch to absolute positioning
              	M400													; Wait for all moves to be completed
              	M98 P"/macros/ZProbe/Klicky/klicky_status.g"			; Check for probe status
              	echo sensors.probes[0].value[0]							; Show the probe status
              if global.klicky_status = "attached"						; Check for the status and make sure it's attached
              	echo "Probe ATTACHED"
              else
              	echo "Error probe not attached - aborting"				; Abort running task if probe isn't attached successfuly
              	abort
              and here is my unload macro (which probably isn't the problem because it doesn't get to this point when the loop runs infinite)
              ; Dock the klicky probe
              if global.klicky_status != "docked"							; Check if the probe isn't docked already
              	echo "Docking Klicky Probe"
              	G90 													; Switch to Absolute positioning
              	M98 P"/macros/Predefined Locations/klicky_location.g" 	; Move in front of probe dock
              	G1 X-60 F99999 	 										; Move into the dock
              	G1 Y30 F99999 											; Move to unhook probe
              if global.klicky_status = "docked"							; Check if the probe is docked
              	echo "Probe is DOCKED"
              else														; Abort the current action if the probe isn't docked correctly
              	echo "Error probe not docked - aborting"
              	abort
              • OwenDundefined
                OwenD @mher
                @mher
                The macros themselves look ok
                There is a limit to the number of nested macros you can have, but I'm not sure what it is.
                I suspect when the main calls your klicky macro, which in turn calls another, then the local variables in the original are lost.
                Can you try calling your macro before you declare the variables?
                mherundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • mherundefined
                  mher @OwenD
                  Maybe @Phaedrux or @dc42 can comment about what the limit of the macros is, if there is such a thing and if that could be the cause of the while loop not exiting correctly.
                  • OwenDundefined
                    OwenD @mher
                    @mher
                    What firmware version are you running?
                    Someone else was having similar issues here
                    https://forum.duet3d.com/topic/29070/weird-macro-behaviour?_=1668050444951
                    • mherundefined
                      mher @OwenD
                      @OwenD
                      I'm running 3.4.0 currently so maybe there is a issue in there as well.
                      For now I've worked around it by doing the if check in the while loop which works it's just not that clean.
                        dc42 administrators @mher
                        @mher that's odd, please try this and tell me if it works for you (it works for me):
                          echo iterations
                          G4 S1
                        • mherundefined
                          mher @dc42
                          Yeah I already created a macro like that to perform the same test and it was working as expected.
                          Just did the same for the code you shared just to be sured and again it worked like expected.
                            dc42 administrators @OwenD
                            @OwenD said in while loop doesn't end:
                            That shouldn't be the case, but of course there may be bugs in the implementation.
                            There is a limit of 10 nested stack pushes. A macro call (whether explicit or implicit) counts as a push, so does using M120. Within each stack push there is also a block nesting limit of 10, so while- and if-else bodies can't be nested more than 10 deep.
                            @mher if you can identify what it is that you are doing in your macro that causes the while-loop to misbehave, I will look into it.
                            mherundefined 2 Replies Last reply Reply Quote 0
                            • mherundefined
                              mher @dc42
                              As far as I can see really quickly i'm max nesting 5 pushes. However lets say i'm inside a while inside an if statement and I call a macro in this if statement and inside the macro itself there are additional if statements. Do they get counted towards the max bodies deep you can nest? If so that might be an issue
                              I'm also assuming that there isn't a max of how many macros you can call in 1 macro?
                              So if i would call M98 30 times in succession it should be fine?
                              • OwenDundefined
                                OwenD @mher
                                It may be unrelated but...
                                Just as a matter of interest, what happens when you send a command like G1 X100 Y100 F99999 ?
                                It will no doubt be restricted by the max speed you set with M203, but if that speed is causing an error condition it may be a factor.
                                I think you're going to have to heavily lace your code with echo commands so you can see where in the scheme of things your issue is appearing.
                                • mherundefined
                                  mher @OwenD
                                  @OwenD As far as I understood it it will execute the command and the speed will be capped at the max you set in the firmware. So max speed for x is currently 10800 (for me atleast). So setting it to F999999 will make sure that when I share this in the vcore3 group (I'm running a vcore3) other people can use it with the speeds they have set on their setup.
                                  I've been adding echo's the thing is that it just seems to fail on the "while iterations" check.
                                  Because I've got it working now by just doing a check inside the while to break the code.
                                  I even setup a testing file with a while loop and loading/unloading the probe which works as expected.
                                  • mherundefined
                                    mher @dc42
                                    Alright it seems like i figured out what is causing the issue.
                                    I created a new macro and started adding things one by one.
                                    Everything went fine until I added this line:
                                    G91 G1 H2 Z7 G90 ; Set to relative positioning, move Z up 5mm, change back to absolute positioning
                                    after adding this the while loop kept on running. After removing it everything ran as expected again
                                    EDIT:
                                    just confirmed it by creating the following macro. This would just keep running the while loop infinite.
                                    G91 G1 Z5 G90 ;Removed H2 to be sure this wasn't the cause
                                    	echo "iteration: " ^ iterations
                                    Then I split the G91/G90 command from single line to multi line and it started working as expected. So it seems there is an issue with the single line implementation for relative/absolute.
                                    Which I read here we should be able to do the way I did
                                    https://forum.duet3d.com/topic/11662/treat-g90-g91-and-m82-m83-like-g53/3
