    Thoughts on an auto-z offsett macro
    Gcode meta commands
    1.2k
    • Exerqtorundefined
      Exerqtor
      My current workhorse is a Voron trident powered by a Duet Mini 5+ with a 1LC running RRF 3.4.4 and with that also using both a bed probe (klicky probe), and a nozzle probe located next to the bed.
      The RRF macro's avalible for Voron printers don't get much work done if any at all, and the exisisting versions of the "auto-z" macro were somewhat outdated. Not using a much of the newer conditional commands we have to our disposition now.
      So i sat out to make a new one, would be cool to get some input on what the hivemind thinks about it. And PLEASE come with hints on improvements or more importantly any errors/bugs!
      I would say most sub-macros are quite self explanatory, but if you(?) want me to add them to see what they contain just say so
      ; /sys/lib/z_cal.g  (v2.2)
      ; Called when "M98 P"/sys/lib/z_cal.g" is sent
      ; Used to calibrate the Z offsett between the Nozzle and buildplate.
      ; report whats going on
      M291 R"Z Offset Calibration" P"Please wait..." T0                              ; leveling bed message
      ; preparation before probing
      ; the distance from the body of the klicky probe to it's own trigger point
      var base_Hot_offset     = global.klicky_offset
      var add_Cold_offset     = 0.06
      ; remember the old offsets
      var old_k0_offset       = sensors.probes[0].triggerHeight                      ; old klicky offset
      var old_k1_offset       = sensors.probes[1].triggerHeight                      ; old z-pin offset
      ; reset existing calibration
      G31 K0 Z7.50        ; reset klicky
      G31 K1 Z0.00        ; reset z-pin
      ; variables for klicky calculation
      var temp0               = 0                                                    ; placeholder value
      var temp1               = 5                                                    ; placeholder value
      var temp2               = 10                                                   ; set value above target value
      ; variables for z-pin calculation
      var temp3               = 0                                                    ; placeholder value
      var temp4               = 2.5                                                  ; placeholder value
      var temp5               = 5                                                    ; set value above target value
      ; Make sure all axes are Homed
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed           ; if axes aren't homed
        G28        ; home all axes
      else
        G28 Z        ; probe nozzle to make Z is correct anyways
      ; LED status
      set global.sb_leds = "homing"
      ; Lower currents, speed & accel
      M98 P"/sys/lib/current/xy_current_low.g"                                       ; set low XY currents
      M98 P"/sys/lib/current/z_current_low.g"                                        ; Set low Z currents
      M98 P"/sys/lib/speed/speed_probing.g"                                          ; set low speed & accel
      if move.axes[2].userPosition < 20
        G1 Z20 F2400        ; lower Z
      M401 P0        ; load the klicky probe
      ; calibrate klicky
      ; position for probing
      G1 X{global.z_pin_x - 4} Y{global.z_pin_y - 23.5} F18000                       ; move the klicky body over the Z-pin
      G1 Z10 F2400        ; move probe closer to z-pin
      ; lower probing speed for accuracy
      M558 K1 F100:50        ; lower probing speed
      ; probe klicky body on Z-pin, minimum 0.004mm accuracy
      while var.temp2 >= 0.004
        G30 K1 S-1        ; probe the klicky body with the Z-pin and report value
        M400        ; wait for moves to finish
        ; lift from z-pin
        G91        ; relative pos
        G1 Z2 F500        ; quickly move up 2mm
        G90        ; absolute pos
        ; save first probe result
        set var.temp0 = sensors.probes[1].lastStopHeight
        ;probe klicky body on Z-pin again
        ; lift from z-pin
        G91        ; relative pos
        G90        ; absolute pos
        ; save second probe result
        set var.temp1 = sensors.probes[1].lastStopHeight
        ;calculate deviation
        set var.temp2 = (var.temp0-var.temp1)
      ; calculate the new klicky offset
      var new_k0_offset       = {((var.temp0 + var.temp1) / 2) + var.base_Hot_offset}
      ; compensate for cold extruder
      if heat.heaters[1].current < 160
        set var.new_k0_offset = {var.new_k0_offset + var.add_Cold_offset}
      ; enable the new klicky offset
      G31 K0 Z{var.new_k0_offset}                                                    ; apply the new Z offsett value
      ; return standard probing speed
      M558 K1 F600:180                                                               ; reset probing speed to normal values
      ;echo the klicky offset
      echo "Old Klicky offset " ^ var.old_k0_offset ^ " New Klicky offset " ^ var.new_k0_offset
      ; calibrate Z-pin
      ; move bed away from nozzle
      G1 Z10 F2400        ; lower the bed
      M98 P"/sys/lib/goto/bed_center.g"                                              ; move to the center of the bed
      M558 K0 F100:50        ; lower probing speed
      ; probe the bed, minimum 0.004mm accuracy
      while var.temp5 >= 0.004
        G30 K0 S-1        ; probe the klicky body with the Z-pin and report value
        ; lift from z-pin
        G91        ; relative pos
        G90        ; absolute pos
        set var.temp3 = sensors.probes[0].lastStopHeight
        ; lift from z-pin
        G91        ; relative pos
        G90        ; absolute pos
        set var.temp4 = sensors.probes[0].lastStopHeight
        set var.temp5 = (var.temp3-var.temp4)
      ; calculate the new z-pin offset
      var new_k1_offset       = {var.new_k0_offset - ((var.temp3 + var.temp4) / 2)}
      ; enable the new z-pin offset
      G31 K1 Z{var.new_k1_offset}                                                    ; apply the new Z offsett value
      M558 K0 F600:180                                                               ; reset probing speed to normal values
      G1 Z{global.klicky_clearance} F2400                                            ; lower the bed
      ;echo the z-pin offset
      echo "Old Z-pin offset " ^ var.old_k1_offset ^ " New Z-pin offset " ^ var.new_k1_offset
      ; finish up
      ; save the new offsets
      M500 P10:31        ; store the new Z offsett values to config-override.g
      G4 P250        ; wait 250 milliseconds
      M402 P0        ; dock the klicky probe
      ; home z with the new offsets
      G28 Z
      set global.Z_cal        = true
      M291 R"Z Offset Calibration" P"Done" T5                                        ; bed leveling done message
      ;LED status
      set global.sb_leds = "ready"
      1 Reply Last reply Reply Quote 4
      • Exerqtorundefined
        Exerqtor
        Thought it might be nice to see how it works/works in it's current state:
        https://www.youtube.com/watch?v=Y0DqT1mv7hs
        • jbjhjmundefined
          jbjhjm
          Great work! I'm thinking of adding such a setup to my V-Core in the future. Thanks for sharing, this will be helpful! It was a bit difficult to see in the vid... what sensor is being used to measure the nozzle Z position? The demo that I recently saw had an aditional fixed Z probe mounted in a corned of the bed, but watching the video it looks like you use a different approach.
          Exerqtorundefined mherundefined 2 Replies Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @jbjhjm
            @jbjhjm Thanks, it's working pretty well. Ofc you may have to tweak the trigger distance to fit the switches you use to make it perfect.
            Yeah sorry the video was done right before i did a print, so the chamber was warm and i didn't want to open the doors and let out the heat 😅
            But it's one microswitch thats stationary relative to the bed surface to probe the nozzle tip (first and last parts of the macro).
            • mherundefined
              mher @jbjhjm
              @jbjhjm On the v-core we can't run the z probe in the position the voron can simply due to the fact that the toolhead never really goes out of bounds of the bed anywhere. While on the voron some space is left at the back to move out of bounds of the bed.
              I'm currently working on getting this to work for the V-core at the back of the bed which brings me to a question for you @Exerqtor
              In your experience, is it required to probe the body of the klicky/euclid probe or could we also get away with probing another "static" part on the toolhead for instance the fan duct and set the offset for this.
              The reason I'm asking is because we can't reach the klicky body in the back of the v-core but we can reach the nozzle and the fan duct. So my current approach is to do it this way but maybe you can say more about this before I pour even more time in my current idea (which is actually almost at a point where I need to start writing code for it)
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @mher
                @mher said in Thoughts on an auto-z offsett macro:
                I haven't had to done this my self obviously, but if you're certain that the spot you choose to probe on the toolhead is static relative to the trigger distance of the klicky it should just be a matter of manually getting what this height is (either via CAD or with calipers or something like that, and dialing it with babystepping til you have the correct value).
                This value should then be input as global.klicky_offset, wherever you choose to define that. I've got all my globals defined and exceuted on startup thru a macro i call globals.g.
                You would of course also alter this part of the code so that the toolhead moves over to the point where you want the toolhead to be probed:
                ; calibrate klicky
                G1 X"WHERE YOU WANT TO PROBE" Y"WHERE YOU WANT TO PROBE" F18000                ; move the klicky body over the Z-pin~~
                I've got a example of my RRF config on github if you want to give it a look.
                Just as a full disclaimer i can't guarantee that what were talking about here would work, but unless i've overseen something critical the above mentioned should work.
                mherundefined 1 Reply Last reply Reply Quote 0
                • mherundefined
                  mher @Exerqtor
                  @Exerqtor Thanks for the response. I was thinking the same just wanted to verify.
                  I'll continue with my implementation and I'll most likely use your script as inspiration but I have some ideas of changing it. I hope to have something working around next week. I'll also update here if I got something up and running
                  Exerqtorundefined 1 Reply Last reply Reply Quote 1
                  • Exerqtorundefined
                    Exerqtor @mher
                    @mher Yeah, you might want to change the reset values for the probe at the start too. If you need more than 7.5mm i mean
                    Would love to hear what changes you were thinking about! And how it goes ofcoursue 😅
                    • Exerqtorundefined
                      Exerqtor @Exerqtor
                      Have to "bite the bullet"a little bit here and admit defeat when it comes to calculating the offset for both probes.
                      And since i'm moving over to direct nozzle probing and ditching that second probe static to the bed i'm not inclined to try fixing it either 🤣
                      So i've opted to turn off the Z-pin offset calculation in the newest version of this script.
                      And with that i've also moved over to doing all Z homing with the klicky probe rather than on the Z-pin. This removes one "fudge" factor by only using the Z-pin to calculate the Klicky-probe offsett AND it makes transitioning to direct nozzle probing a little bit easier since down the road when it comes to homing macros etc.
                      Version 2.3 of the macro:
                      ; /sys/lib/z_cal.g  (v2.3)
                      ; IMPORTANT!! Do you wish to calibrate K1 / Z-pin as well? (Not working like intended as of v2.3 so I would advice to not use it!)
                      var calibrate_Z_Pin = false
                      ; Preparation before probing
                      ; Report whats going on
                      M291 R"Z Offset Calibration" P"Please wait..." T0                              ; Leveling bed message
                      ; The distance from the body of the klicky probe to it's own trigger point
                      ; Remember the old offsets
                      var old_k0_offset       = sensors.probes[0].triggerHeight                      ; Old klicky offset
                      var old_k1_offset       = sensors.probes[1].triggerHeight                      ; Old z-pin offset
                      ; Reset existing calibration
                      G31 K0 Z7.50        ; Reset klicky
                      G31 K1 Z0.00        ; Reset z-pin
                      ; Variables for klicky calculation
                      var temp0               = 0                                                    ; Placeholder value
                      var temp1               = 5                                                    ; Placeholder value
                      var temp2               = 10                                                   ; Set value above target value
                      ; Variables for z-pin calculation
                      var temp3               = 0                                                    ; Placeholder value
                      var temp4               = 2.5                                                  ; Placeholder value
                      var temp5               = 5                                                    ; Set value above target value
                      ; Message placeholder
                      var consoleMessage1 = "N/A"
                      M290 R0 S0        ; Clear babystepping
                      ; LED status
                      ; Home all axes and lower the bed
                      ; Make sure all axes are homed, and home Z again anyways
                      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed           ; If axes aren't homed
                        ; Home all axis
                        G91        ; Relative positioning
                        M98 P"/sys/lib/current/xy_current_low.g"                                     ; Set low XY currents
                        M98 P"/sys/lib/speed/speed_probing.g"                                        ; Set low speed & accel
                        ; Lower Z relative to current position if needed
                        if !move.axes[2].homed                                                       ; If Z ain't homed
                          G1 Z20 F9000 H1                                                            ; Lower Z(bed) relative to current position
                        elif move.axes[2].userPosition < 10                                          ; If Z is homed and less than 10
                          G1 Z20 F9000                                                               ; Move to Z 10
                        ; Coarse home X or Y
                        G1 X600 Y600 F2400 H1                                                        ; Move quickly to X or Y endstop(first pass)
                        ; Coarse home X
                        G1 X600 H1        ; Move quickly to X endstop(first pass)
                        ; Coarse home Y
                        G1 Y600 H1        ; Move quickly to Y endstop(first pass)
                        ; Move away from the endstops
                        G1 X-5 Y-5 F9000                                                             ; Go back a few mm
                        ; Fine home X
                        G1 X600 F360 H1                                                              ; Move slowly to X axis endstop(second pass)
                        ; Fine home Y
                        G1 Y600 H1        ; move slowly to Y axis endstop(second pass)
                        ; Absolute positioning
                        G90        ; Absolute positioning
                        ; Home Z
                        ; Load the probe
                        M400        ; Wait for moves to finish
                        M98 P"/sys/lib/klicky/klicky_status.g"                                       ; Refresh klicky status
                        M401 P0        ; Load the klicky probe
                        ; Last check to ensure klicky is attached
                        if global.klicky_status = "attached"
                          echo "Probe ATTACHED"
                        else
                          echo "Error probe not attached - aborting"
                          M291 T5 R"Z Homing Aborted!" P"Z haven't been homed - check probe"
                          abort
                        ; Move to bed center and home Z
                        M98 P"/sys/lib/goto/bed_center.g"                                            ; Move to bed center
                        G30 K0 Z-99999                                                               ; Probe the center of the bed
                      else
                        ; Home Z axis-
                        ; Do nothing if XY is not homed yet
                        if move.axes[0].homed && move.axes[1].homed
                        ; Load the probe
                        else
                          abort
                        G1 Z20 F2400        ; Lower Z
                      ; Calibrate klicky
                      ; Position for probing
                      G1 X{global.z_pin_x - 4} Y{global.z_pin_y - 23.5} F18000                       ; Move the klicky body over the Z-pin
                      G1 Z10 F2400        ; Move probe closer to z-pin
                      ; Lower probing speed for accuracy
                      M558 K1 F100:50        ; Lower probing speed
                      ; Probe klicky body on Z-pin, minimum 0.004mm accuracy
                        G30 K1 S-1        ; Probe the klicky body with the Z-pin and report value
                        ; Lift from z-pin
                        G1 Z2 F500        ; Quickly move up 2mm
                        ; Save first probe result
                        ; Probe klicky body on Z-pin again
                        ; Lift from z-pin
                        ; Save second probe result
                        ;Calculate deviation
                      ; Calculate the new klicky offset
                      ; Compensate for cold extruder
                      if heat.heaters[1].current < 150
                      ; Enable the new klicky offset
                      G31 K0 Z{var.new_k0_offset}                                                    ; Apply the new Z offsett value
                      ; Return standard probing speed
                      M558 K1 F600:180                                                               ; Reset probing speed to normal values
                      ; Make a report message
                      set var.consoleMessage1 = "Old Klicky offset " ^ var.old_k0_offset ^ " New Klicky offset " ^ var.new_k0_offset
                      ; Calibrate Z-pin
                      ; Check if Z-Pin calibration is enabled or not
                      if var.calibrate_Z_Pin
                        var consoleMessage2 = "N/A"
                        ; Move bed away from nozzle
                        G1 Z10 F2400        ; Lower the bed
                        M98 P"/sys/lib/goto/bed_center.g"                                            ; Move to the center of the bed
                        M558 K0 F100:50                                                              ; Lower probing speed
                        ; Probe the bed, minimum 0.004mm accuracy
                          G30 K0 S-1        ; Probe the klicky body with the Z-pin and report value
                          ; Lift from z-pin
                          ; Lift from z-pin
                        ; Calculate the new z-pin offset
                        ; Enable the new z-pin offset
                        G31 K1 Z{var.new_k1_offset}                                                  ; Apply the new Z offsett value
                        M558 K0 F600:180                                                             ; Reset probing speed to normal values
                        G1 Z{global.klicky_clearance} F2400                                          ; Lower the bed
                        set var.consoleMessage2 = "Old Z-pin offset " ^ var.old_k1_offset ^ " New Z-pin offset " ^ var.new_k1_offset
                      ; Finish up
                      ; Save the new offsets
                      M500 P10:31        ; Store the new Z offsett values to config-override.g
                      G4 P250        ; Wait 250 milliseconds
                      ; Lower bed to reduce pucker factor
                      G1 Z20 F9000        ; Move to Z 20
                      ; Home z with the new offsets
                      ; Report the new offsets
                      ;K0 / klicky probe
                      M118 P2 S{var.consoleMessage1}  ; send used probe grid to paneldue
                      M118 P3 S{var.consoleMessage1}  ; send used probe grid to DWC console
                        ;K1 / Z-pin
                        M118 P2 S{var.consoleMessage2}  ; send used probe grid to paneldue
                        M118 P3 S{var.consoleMessage2}  ; send used probe grid to DWC console
                      ; Dock the probe
                      M402 P0        ; Dock the klicky probe
                      ; Full currents, speed & accel
                      M98 P"/sys/lib/current/z_current_high.g"                                       ; Restore normal Z currents
                      M98 P"/sys/lib/current/xy_current_high.g"                                      ; Set high XY currents
                      M98 P"/sys/lib/speed/speed_printing.g"                                         ; Restore normal speed & accels
                      ; Lower Z(bed) after probing
                      G1 Z5 F2400        ; Move to Z 5
                      M291 R"Z Offset Calibration" P"Done" T5                                        ; Bed leveling done message
                      ;LED status
                      I've also moved all the homing portion fully into the macro itself rather than calling for G28 or G28 Z that makes it "deploy" and "retract" the probe way to many times.
                      @mher
                      • droftartsundefined droftarts referenced this topic
                      • alexusundefined alexus referenced this topic
