    Turn off the z-axis limit switch
    • Proschi3Dundefined
      Proschi3D
      how can i turn off the z-axis limit switch
      I want to pass the z-max limit switch to calibrate the x-axis
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
      deckingmanundefined Norderundefined 2 Replies Last reply Reply Quote 0
      • deckingmanundefined
        deckingman @Proschi3D
        @Proschi78 This is a strange thing to want to do, but you could temporarily change the axis minimum to take a negative number or increase the axis maximum depending on which end of the axis travel you want to increase l. Do that at the start of homing X then put it back at the end.
        Proschi3Dundefined 1 Reply Last reply Reply Quote 0
          Proschi3D @deckingman
          @deckingman
          thanks
          better I do this via a macro.
          I have two z motors on one driver.
          I want to use it to align the x axis by moving z to the upper stops
            @Proschi78 said in Turn off the z-axis limit switch:
            @deckingman
            thanks
            better I do this via a macro........
            HomeX is a macro - so you can put the necessary commands in there, rather than write another macro.
            • Norderundefined
              Norder @Proschi3D
              @Proschi78
              With this command you switch the axis limit on or off.
              https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m564-limit-axes
              However, the project should be treated with caution!
              DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
              Thingiverse
