    G32 TRUE BED LEVEL SCRIPT
    • Shanian79undefined
      Shanian79
      When using G32, Does G32 need to be added to the staring scripts on the slicer or does the Duet2Wifi save the compensation until its manually run again?
      alankilianundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @Shanian79
        @Shanian79 G32 just runs bed.g so you'll need to look in your specific bed.g to see what it does.
        Also you should look at your config.g to see if it loads any previously-saved bed compensation.
        Bed compensation page.
        Shanian79undefined 1 Reply Last reply Reply Quote 0
          Shanian79 @alankilian
          @alankilian G32 runs bed.g and then makes corrections to the axis programed in bed.g
          It is not the same as mesh comp as far as I understand it.
            True, but some people just have G29 in their bed.g. So it really depends on how you're using it. So if you show us your bed.g and homing files we can more accurately tell you what persists or doesn't.
              dc42 administrators @Shanian79
              @Shanian79 said in G32 TRUE BED LEVEL SCRIPT:
              The compensation is not saved because the leadscrew positions will jump when you power off and on again. Therefore you should run it after powering up before you do the first print.
