    Error code when using M471
    Gcode meta commands
    macros m471
    443
    • ApTixundefined
      ApTix
      So I'm in the trying to make a backup of my old bed mesh to reference. The issue I'm having isnt with the function but it spits out error code when doing it.
      Like it does rename the file heightmap_00 to .bak, but it spits out the error code underneath. Am I doing something wrong?
      Tried using the command in the console and in a macro but same result. It renames the file but spits out the same error code
      Using this command:
      M471 S"/sys/heightmap_00.csv" T"/sys/heightmap_00.csv.bak" D1
      Error code:
      Error: M471: Failed to rename file or directory /sys/heightmap_00.csv to /sys/heightmap_00.csv.bak: Unable to find the specified file.
      Using duetweb on a raspberry 4 8gb
      Board: Duet 3 6HC
      DSF 3.4.3
      jay_s_ukundefined chrishammundefined 2 Replies Last reply Reply Quote 1
        jay_s_uk @ApTix
        @ApTix one for @chrishamm
        what you're trying to do looks ok to me
          Do your DSF and Duet firmware versions match?
          ApTixundefined 1 Reply Last reply Reply Quote 0
          • ApTixundefined
            ApTix @Phaedrux
            @Phaedrux
            Board: Duet 3 MB6HC (MB6HC)
            DSF Version: 3.4.3
            Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.3 (2022-10-05)
              Can you try renaming, but keep the csv extension?
              • ApTixundefined
                ApTix @Phaedrux
                @Phaedrux I tried to rename the file to heightmap_00.bak.csv and heightmap_00_bak.csv with or without D1 in M471 but still the same result…it renames the file but gets the same error code.
                  Sounds like maybe a permissions issue, but @chrishamm would know more.
                  Is this with a stock Duet Pi image? Might not be a bad time to try a fresh image download and update to 3.4.4.
                  • ApTixundefined
                    ApTix @ApTix
                    @Phaedrux its running mjpg-streamer beside the duet application for a camera stream. maybe updating would help...but it seems more like a bug than permission issues since it does change the name of the file? like it does work but error codes pops out?
                    • chrishammundefined
                      chrishamm administrators @ApTix
                      @ApTix Thanks for reporting this, it will be fixed in the next version.
                      Duet software engineer
