    choosing motor with low vibration for ender 3
    393
    • morisundefined
      moris
      Hi all
      I Have ender 5 with original motors but I am struggling with vibration
      on x and y axis
      I am using Duet WiFi with TMC 2660
      all my effort to reduce the vibration are leading to the motors
      this is not a belt or pulley issues or extruder motor only x and y motors
      I already search in the net and special on this forum
      the Y motor is dual shaft
      I need you to help me find a good motors that are working well with TMC 2660 drivers
      Thank you
        What kind of vibrations are you seeing/hearing? Is it just noisy, or are you seeing print artifacts?
        I think these would pair well with the Duetwifi on an ender3.
        https://www.omc-stepperonline.com/nema-17-bipolar-45ncm-64oz-in-2a-42x42x40mm-4-wires-w-2300mm-91-cable-17hs16-2004s-c5
        morisundefined 2 Replies Last reply Reply Quote 0
        • morisundefined
          moris @Phaedrux
          @Phaedrux
          they are vertical line without relation to any shape
          if print XYZ calibration cube there is no ringing to Y axis
          only vertical lines same spot same amount
          • morisundefined
            moris @Phaedrux
            @Phaedrux
              I can't make out much from that photo.
              • A Former User?
                A Former User @moris
                @moris Have you considered motor dampers? They helped quite my machine, not sure if they improved print quality at all.
                https://www.amazon.com/s?k=nema+17+damper&i=industrial&crid=1WB28PE9RALN8&sprefix=nema+17+dampe%2Cindustrial%2C188&ref=nb_sb_noss_2
                Also, if you have your current settings wrong that might be an issue too. I had to tweak mine several times to find the right values.
                morisundefined 1 Reply Last reply Reply Quote 1
                • morisundefined
                  moris @A Former User
                  @wwak84
                  I try everything in the web
                  Frame and motors the only thing I did it change
                    dc42 administrators @moris
                    @moris please post your config.g file so that we can check what settings you are using.
