Milling motor control - Duet3/PWM Converter
@Nightowl thats where you'll be going wrong then as the header you're using is always on (i think). change numbers 3 and 4. it'll also probably explain why its always on at power up without that relay. i would just wire them to an out connector and switch your M950 accordingly.
@Nightowl ah bugger, you're right. i looked at the diagram wrong
All sorted, thank you gentlemen!
It was in fact down to way the PWM converter was connected to the Duet board.
I'll amend my diagram and publish it here (and delete the earlier one!
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
Here's the updated connection diagram:
...and this is the code from the config.g file:
; Milling motor and relay configuration M950 R0 C"vfd+out7" L4000:25000 Q1000 ; enable router relay on out7 M563 P0 S"St George" R0 ; assign spindle 0 to tool 0 and name it St George T0 ; select tool 0 M5 ; ensure motor is turned off
Note: I have used this relay to provide mains power to the milling motor, which is activated from Out7 in this case. I guess any Out could be used, but the code would need to be changed accordingly.
Many thanks to @dc42 and @jay_s_uk for helping me resolve this, and I hope this diagram will be of use to others.
undefined Nightowl referenced this topic
