Tall 3D printers under 5000$/€
i work in orthopedics and we're using a Raise 3d pro 2+ which is fine, but now that we need an additional printer I dont want to buy a 5 year old machine for ~5000€.
The new Pro 3+ however costs 7700€ which is a bit above my budget.
I have looked far and wide for hobby level machines which are totally fine for what we print, but they usually go only up to 400-500mm in Z height, and we need a minimum of 600mm.
So Id like to ask the crowd inteligence: Have you found a normal fdm 3d printer for under 5000€ with a minimum build hight of 600mm?
Cheers
F. -
I work for a company called Modix3D, and we create large printers at a pretty tight budget. The big60 model is 600x600x660 (XYZ) for $4950+shipping, so it's right around your budget
@ComedianTF2 Yes thats was actually my first choice.
I wanted the 120Z version, but it only comes as a kit and its company policy to only buy full service machines and i wasnt trusted with building the thing myself.also if you add the comfort features it ends up more on the 6000 side
but good thinking.
@sungod3k what bed size does the printer need to meet your requirements? The Tractus3D T1250 might meet your requirements if a 350mm diameter bed is large enough.
@dc42 yes, i contacted them also, they were a bit slow with the communication and 350 is a bit on the smaller side, but yes tractus is still on my shortlist.
