    Configuring X stop for "e0stop" pin
    • Ian Millerundefined
      Ian Miller
      I'm having trouble getting my duet wifi 2 to recognize that I have remapped the endstop for the X axis to the "e0stop" pin. Despite seeing the led next to the correct driver flash off when the endstop is pressed, when using the m119 command to check endstop status it reads triggered whether or not the endstop is pressed. I've tried messing around with it for a bit but still haven't found anything that works. Despite this minor issue the Y stop works perfectly as is.
      Here is my config:
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 p4 s1
      M584 X3 Y0 Z1 ; set drive mapping
      M584 E4
      M92 X80 Y80 Z400
      M92 E453 ; Set steps per mm
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M566 X1200 Y1200 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z600 E3000:3000 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z100 E25:250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout ; Set idle timeout
      M208 X0 Y-3 Z0 S1 ; set axis minima
      M208 X275 Y300 Z360 S0 ; set axis maxima
      M574 X1 S1 P"e0stop"
      M574 Y1 S1 P"ystop"
      M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. Not using on XY, but using it on Z.
      G31 P25 X34 Y-17 Z3.1 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 x50:250 Y50:250 s30
      ;filament out sensor
      M591 D4 P1 C"e1stop" S1
      ; BLTouch - Heaters
      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex bo
      M143 S265 ; Set maximum heater temperature to 265C
      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B3950 C0 R4700
      m570 T200
      M950 F2 C"fan0" Q500
      M106 P1 C"Part cooling fan" S1 ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 S"Hotend 0" D1 H2 F2 ; define tool 0
      ; Custom settings
      m552 s1
      Any ideas would be great.
        Can you send M122 and M98 P"config.g" in the gcode console and report the results here?
        Ian Millerundefined 1 Reply Last reply Reply Quote 0
          Ian Miller @Phaedrux
          @Phaedrux 05c8cbbc-d72c-4609-9aed-4c5294b7b5fa-image.png image url)
          Sent the reboot command then followed with M98"config.g". I haven't finished setting up the tool and don't have thermistors or heaters connected currently.
            Phaedrux Moderator @Ian Miller
            @Ian-Miller said in Configuring X stop for "e0stop" pin:
            No, M112 is restart. M122 is the diagnostic report.
            The array too long errors are because you have two values listed for the extruder on some commands, but only 1 extruder drive mapped.
              jay_s_uk @Ian Miller
              @Ian-Miller there is also a mix of rrf2 and rrf3 commands in your config. For example, M305 works in rrf2 but not rrf3. Assigning endstops like you have works in rrf3 but not rrf2
