    CONSTANT AJAX disconnect errors
    1.0k
    • patelundefined
      patel
      M122
      Used output buffers: 3 of 32 (6 max)
      RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
      Board ID: 08DDM-9FAM2-LW4SD-6J9D6-3SN6L-12ZHY
      Static ram used: 21176
      Dynamic ram used: 95976
      Recycled dynamic ram: 1632
      Stack ram used: 1304 current, 4880 maximum
      Never used ram: 7408
      Last reset 00:12:06 ago, cause: power up
      Last software reset reason: User, spinning module GCodes, available RAM 3192 bytes (slot 2)
      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 26.1, current 34.9, max 36.7
      Supply voltage: min 11.4, current 12.1, max 12.5, under voltage events: 0, over voltage events: 0
      Driver 0: standstill
      Driver 1: standstill
      Driver 2: standstill
      Driver 3: standstill
      Driver 4: standstill
      Date/time: 2017-11-06 13:50:27
      Slowest main loop (seconds): 0.005554; fastest: 0.000034
      MaxReps: 8, StepErrors: 0, FreeDm: 240, MinFreeDm 239, MaxWait: 4122ms, Underruns: 0, 0
      Scheduled moves: 4, completed moves: 4
      Bed compensation in use: none
      Bed heater = 0, chamber heater = -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.19
      WiFi MAC address 2c:3a:e8:0a:f1:18
      WiFi Vcc 3.08, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 39528
      WiFi IP address 192.168.0.22
      WiFi signal strength -77dBm
      Reconnections 0
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0
      • KeeganBundefined
        KeeganB
        Patel,
        We have a long and ongoing discussion for this issue here: https://www.duet3d.com/forum/thread.php?id=2628
        I think it would be more beneficial for everyone if you joined that conversation rather than having two separate threads.
        Thanks!
        Artemis
        Rostock Max v2
        Orion
        • elmoretundefined
          elmoret
          If you haven't already, would recommend reading this:
          https://www.duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors
          Your -77dBm signal strength is rather weak, and indicates something is blocking the signal from your router or the router is far from the Duet.
          • patelundefined
            patel
            my printer near router is see -35dBm signal strength. still I getting AJAX error.
            • patelundefined
              patel
              I am still getting error. Any one know. how about I use panel touch to the my duet wifi. I can resolve this problem. I am tried to resetting.
                If you get an AJAX error and you can't reconnect, try sending M552 S0 followed by M552 S1 from PanelDue. This forces a disconnect and reconnect form the access point. After a few seconds, you should get a message on the PanelDue saying whether the reconnect was successful or not. Then try reconnecting the browser again.
                If that doesn't work, try M552 S-1 followed by M552 S1 instead.
                I have a new build of DuetWiFiServer under development, which I hope will either fix these issues or at least make the cause easier to track down.
                • patelundefined
                  patel
                  today morning i connect duet WIFI it works but 12.21.45pm start and 12.44.16pm disconnected, AJAX ERROR has been report
                  also, you mention new build of DuetWiFiServer under development, please can you explain more detail about step to update
                  M122
                  Used output buffers: 9 of 32 (12 max)
                  Dynamic ram used: 96040
                  Recycled dynamic ram: 1568
                  Stack ram used: 1304 current, 9096 maximum
                  Never used ram: 3192
                  Last reset 00:51:31 ago, cause: software
                  Last software reset reason: User, spinning module GCodes, available RAM 7408 bytes (slot 4)
                  Error status: 0
                  SD card longest block write time: 5.4ms
                  MCU temperature: min 31.0, current 32.8, max 33.3
                  Supply voltage: min 12.0, current 12.0, max 12.2, under voltage events: 0, over voltage events: 0
                  Driver 0: stalled standstill
                  Driver 2: stalled standstill
                  Driver 3: stalled standstill
                  Date/time: 2017-11-07 13:13:01
                  Slowest main loop (seconds): 0.074219; fastest: 0.000000
                  MaxReps: 10, StepErrors: 0, FreeDm: 240, MinFreeDm 210, MaxWait: 112520ms, Underruns: 8, 3762
                  Scheduled moves: 0, completed moves: 0
                  Heater 0 is on, I-accum = 0.0
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  WiFi flash size 4194304, free heap 38192
                  WiFi IP address 192.168.0.114
                  WiFi signal strength -42dBm
                  Reconnections 0
                  Socket states: 2 2 2 2 0 0 0 0
                  Responder states: HTTP(2) HTTP(1) HTTP(1) HTTP(1) FTP(0) Telnet(0)
                    Please see the other thread on the same subject.
                    • T3P3Tonyundefined
                      T3P3Tony administrators
                      Closing this thread so the other one is used,
                      www.duet3d.com
