    Why does my Z hop sound like a hammer.
    652
    • Karimundefined
      Karim
      How can I quiet down my printer Z hop, This is Voron 2.4 3d Printer, <4> Z belts.
      ; Drive directions
      M569 P0 S0 ; A
      M569 P1 S0 ; B
      M569 P3 S1 ; Extruder
      M569 P5 S0 ; Z1
      M569 P6 S1 ; Z2
      M569 P7 S0 ; Z3
      M569 P8 S1 ; Z4
      M584 X0 Y1 Z5:6:7:8 E3                            ; Motor mapping and steps per mm
      M350 X16 Y16 Z16 E16 I1                           ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E562.00                 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00               ; set maximum instantaneous speed changes (mm/min)
      M203 X60000.00 Y60000.00 Z18000.00 E1200.00       ; set maximum speeds (mm/min)
      M201 X6000.00 Y6000.00 Z4000.00 E250.00           ; set accelerations (mm/s^2)
      ; Drive currents
      M906 X1500 Y1500 Z1200 E400 I30                    ; set motor currents (mA) and motor idle factor in per cent
        Try reducing the acceleration.
        Karimundefined 1 Reply Last reply Reply Quote 0
        • Karimundefined
          Karim @Phaedrux
          @Phaedrux on Z like this
          M201 X6000.00 Y6000.00 Z1000.00 E250.00           ; set accelerations (mm/s^2)```
            That's a good start.
            • o_lampeundefined
              o_lampe @Phaedrux
              @Phaedrux
              I still wouldn't recommend using Z-hop on a moving bed printer. There are so many possible side effects when moving a big mass.
              I'd switch it off after the first layer. That's where it is most critical not to scrape the nozzle over the fresh print.
                dc42 administrators @Karim
                @Karim how much Z hop are you using?
                • Karimundefined
                  Karim @dc42
                  @dc42 I am using Prusaslicer 2.5 and this is the only setting I see Z Lift. This printer the Bed is fix and the Nozzle move up and down (Corexy).
                    @Karim that looks reasonable, although you could try using less. I typically use one layer height.
                    • Karimundefined
                      Karim @dc42
                      @dc42 I am using .6 Nozzle and print @.3 layer height. So what else can I check.
                        Did changing the acceleration help?
                        Do you have the tension of the Z belt gear reduction set correctly?
                        • Karimundefined
                          Karim @Phaedrux
                          @Phaedrux lowered Z speed. Sounds better now.
                          Thanks.
