    Enable Retract/Extrude in Extrusion Control
    Duet Web Control
    • crowemundefined
      crowem
      I no longer seem to be able to extrude test some things from the web interface. I know that this was an issues before when i did not have a loaded filament in the interface but now I don't seen an option to load a filament in to enable these options.
        What firmware version and DWC version are you using?
        Can you share your config.g please?
        crowemundefined 1 Reply Last reply Reply Quote 0
        • crowemundefined
          crowem @Phaedrux
          @Phaedrux
          Duet Web Control 3.4.1
          ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Dec 16 2022 11:47:29 GMT-0600 (Central Standard Time)
          G90                                               ; send absolute coordinates...
          M83                                               ; ...but relative extruder moves
          M550 P"Duet 3"                                    ; set printer name
          M569 P0.2 S0                                      ; physical drive 0.2 goes backwards
          M569 P0.1 S0                                      ; physical drive 0.1 goes backwards
          M569 P0.0 S0                                      ; physical drive 0.0 goes backwards
          M569 P0.3 S0                                      ; physical drive 0.3 goes backwards
          M569 P0.4 S1                                      ; physical drive 0.4 goes forwards
          M584 X0.2 Y0.1 Z0.0 E0.3:0.4                      ; set drive mapping
          M350 X16 Y16 Z16 E16:16 I1                        ; configure microstepping with interpolation
          M92 X100.00 Y100.00 Z400.00 E95.00:95.00          ; set steps per mm
          M566 X1200.00 Y1200.00 Z60.00 E1500.00:1500.00    ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z180.00 E6000.00:6000.00 ; set maximum speeds (mm/min)
          M201 X4000.00 Y4000.00 Z20.00 E1000.00:1000.00    ; set accelerations (mm/s^2)
          M906 X900 Y900 Z900 E900:900 I30                  ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                           ; Set idle timeout
          M208 X-127 Y-92 Z0 S1                             ; set axis minima
          M208 X140 Y92 Z160 S0                             ; set axis maxima
          M574 X2 S1 P"!io2.in"                             ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !io2.in
          M574 Y2 S1 P"!io0.in"                             ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !io0.in
          M574 Z1 S2                                        ; configure Z-probe endstop for low end on Z
          M558 P1 C"io3.in" H5 F120 T6000                   ; set Z probe type to unmodulated and the dive height + speeds
          G31 P990 X-10 Y5 Z1.1                             ; set Z probe trigger value, offset and trigger height
          M557 X-95:105 Y-86:90 S10                         ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138      ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                                ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B0 S1.00                                  ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                           ; map heated bed to heater 0
          M143 H0 S280                                      ; set temperature limit for heater 0 to 280C
          M308 S1 P"temp1" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out1" T1                                ; create nozzle heater output on out1 and map it to sensor 1
          M307 H1 B0 S1.00                                  ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                      ; set temperature limit for heater 1 to 280C
          M308 S2 P"temp2" Y"thermistor" T100000 B4138      ; configure sensor 2 as thermistor on pin temp2
          M950 H2 C"out2" T2                                ; create nozzle heater output on out2 and map it to sensor 2
          M307 H2 B0 S1.00                                  ; disable bang-bang mode for heater  and set PWM limit
          M143 H2 S280                                      ; set temperature limit for heater 2 to 280C
          M950 F0 C"out9" Q500                              ; create fan 0 on pin out9 and set its frequency
          M106 P0 C"Pi" S0.8 H0 T10                         ; set fan 0 name and value. Thermostatic control is turned on
          M950 F1 C"out5" Q500                              ; create fan 1 on pin out5 and set its frequency
          M106 P1 C"Extruder Front" S0 H-1                  ; set fan 1 name and value. Thermostatic control is turned off
          M950 F2 C"out8" Q500                              ; create fan 2 on pin out8 and set its frequency
          M106 P2 C"Extruder" S1 H0 T10                     ; set fan 2 name and value. Thermostatic control is turned on
          M950 F3 C"out7" Q500                              ; create fan 3 on pin out7 and set its frequency
          M106 P3 C"duetfan" S0 H0 T10                      ; set fan 3 name and value. Thermostatic control is turned on
          M950 F4 C"out6" Q500                              ; create fan 4 on pin out6 and set its frequency
          M106 P4 C"Extruder back" S0 H-1                   ; set fan 4 name and value. Thermostatic control is turned off
          M563 P0 S"Right" H1 F1:4                          ; define tool 0
          G10 P0 X0 Y0 Z0                                   ; set tool 0 axis offsets
          G10 P0 R0 S0                                      ; set initial tool 0 active and standby temperatures to 0C
          M563 P1 S"Left" H2 F1:4                           ; define tool 1
          G10 P1 X-32.8 Y-0.15 Z0                           ; set tool 1 axis offsets
          G10 P1 R0 S0                                      ; set initial tool 1 active and standby temperatures to 0C
          ; Custom settings
          M501
            jay_s_uk @crowem
            @crowem you don't have any drivers attached to your tools in M563 so there's nothing to extrude with. You need a D value.
            • crowemundefined
              crowem @jay_s_uk
              @jay_s_uk
              That is strange it is set up n the config tool
                That's just the driver to axis mapping. The tools page is later on.
                It produces this section
                G10 P1 R0 S0
                The M563 command needs a D# parameter. D0 is the first extruder listed, and D1 is the second.
                • crowemundefined
                  crowem @Phaedrux
                  @Phaedrux
                  Fixed it thank you. Some how the tool settings got unclicked
                  • dc42undefined dc42 marked this topic as a question
