    Jumping off Z Header (Duet 2)
    • Adam_Sw3undefined
      Adam_Sw3
      Hi all,
      I need just one more stepper motor on my Z (to have 3 in total) and I was wondering if I could split a header between two or something else so that I have one extra motor? or do I have to buy the extension board? I've seen you can get a duet maestro board that has two more motor drivers on, could this be adapted?
      Thanks in advance!
        You could add a Expansion Breakout Board and add an external driver.
        https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/Duet_Expansion_Breakout_Board
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting_external
        Adam_Sw3undefined 1 Reply Last reply Reply Quote 1
        • Adam_Sw3undefined
          Adam_Sw3 @Phaedrux
          @Phaedrux Thanks for this! Thats helped massively!
            dc42 administrators @Adam_Sw3
            @Adam_Sw3 the two Z motor connectors on Duet 2 are connected in series. You could connect two motors in series to one of them, to put all three in series. Google "wiring stepper motors in series" to see how.
            If they are low current motors (e.g. rated at 800mA or less) then it would be better to wire all three motors in parallel to one of the connectors, and put the two jumpers in the other.
