    Extruder Heater and Thermocouple not working
    298
    • asaharundefined
      asahar
      Hi, following is my config file, but my heaters are not working```
      ; Configuration file for Duet 3 MB 6XD (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Thu Dec 01 2022 15:05:36 GMT-0700 (Mountain Standard Time)
      M550 P"Duet 3 6XD Test" ; set printer name
      M552 S0 ; disable network
      M569 P0.0 S0 T10 R0 ; physical drive 0.0 goes backwards
      M569 P0.1 S0 T10 R0 ; physical drive 0.1 goes backwards
      M569 P0.2 S1 T10 R0 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 T10 R0 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X40.00 Y40.00 Z40.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X1800.00 Y1500.00 Z1200.00 E180.00 ; set maximum speeds (mm/min)
      M201 X40.00 Y40.00 Z40.00 E250.00 ; set accelerations (mm/s^2)
      M906 X3150 Y3150 Z4030 E800 ; set motor currents (mA)
      M84 S0 ; Disable motor idle current reduction
      M208 X850 Y700 Z365 S0 ; set axis maxima
      M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
      M558 P0 H5 F120 T360 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      ; Heaters
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
      M308 S1 P"spi.cs0" Y"thermocouple-max31856" K"T"; configure sensor 1 as thermocouple via CS pin spi.cs0
      M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
      M308 S2 P"spi.cs1" Y"thermocouple-max31856" K"T"; configure sensor 2 as thermocouple via CS pin spi.cs1
      M950 H2 C"out2" T2                           ; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                 ; set temperature limit for heater 2 to 280C
      M308 S3 P"spi.cs2" Y"thermocouple-max31856" K"T"; configure sensor 3 as thermocouple via CS pin spi.cs2
      M950 H3 C"out3" T3                           ; create nozzle heater output on out3 and map it to sensor 3
      M307 H3 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H3 S280                                 ; set temperature limit for heater 3 to 280C
      ; Fans
      M950 F0 C"out5" Q500                         ; create fan 0 on pin out5 and set its frequency
      M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      temperatu
      M563 P0 S"Extruder" D0 F0               ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby res to 0C
      Are there any mistakes in the configuration file?
        jay_s_uk @asahar
        @asahar best to run M98 P"config.g" and post the results
          Send M122 as well and post the results here.
          When you say the heaters are not working, what exactly are you trying to do, and what is happening?
          asaharundefined 1 Reply Last reply Reply Quote 0
          • asaharundefined
            asahar @Phaedrux
            @Phaedrux by this I mean that I am not getting any voltage from thermocouple and heaters do not run.
              Phaedrux Moderator @jay_s_uk
              said in Extruder Heater and Thermocouple not working:
              Have you run this yet?
                Phaedrux Moderator @asahar
                @asahar said in Extruder Heater and Thermocouple not working:
                thermocouple
                Are you using a thermocouple daughterboard? Are you sure it's a thermocouple?
                  Error: M303: tool 0 does not use heater 1<LF>ok<LF>
                  Your tool does not have a heater defined at all. It's missing an H parameter.
                  Which heater are you using with the tool?
                  • asaharundefined
                    asahar
                    Yes I am using two thermocouple daughter boards and three T type thermocouples.
                    • asaharundefined
                      asahar @Phaedrux
                      @Phaedrux yes, now I have define H1:3 with Tool 0 which is extruder. Now, I am getting this error
                      m303 h1 p1 s100 t0
                      Error: M303: heater 1 reported error 'unknown sensor' at start of auto tuning<LF>ok<LF>
                      What can b ethe reason?
                        m303 h1 p1 s100 t0
                        This is not a valid command.
                        Try M303 T0 S100 That should try tuning the tool as a whole to 100c. That temp seems low though.
                          Phaedrux Moderator @Phaedrux
                          @Phaedrux said in Extruder Heater and Thermocouple not working:
                          Have you run this yet? M98 P"config.g"
                          • asaharundefined
                            asahar @Phaedrux
                            M98 P"config.g"
                            yes, I run it but have not got any result yet, does it take a long time.
