out0 voltaje
Hello. On documentation I can read:
The separate OUT0 Power in allows for a different voltage to be supplied for the OUT0 high current output (e.g for a large bed heater). If this is not required VIN power must be applied to both the POWER IN and the OUT0 POWER IN terminals for OUT 0 to be powered.
What is the "different voltage" range that I can use? For example can I supply 220V in here to feed a 220V bed heater for example?
@Tinchus no! it must be DC.
Assuming its a 6HC, on versions up to and including 1.01 its 12-36v. on a 1,02 its 12-48v -
@jay_s_uk thanks!
