Extruder motor not working.
So are you still getting phase errors, or is that resolved?
@jfavre said in Extruder motor not working.:
till no luck with Extrusion Control jogging buttons.
Send
T0
in the gcode console and check the buttons again. -
Still no luck with Extrusion Control jogging buttons.
Is the heater up to temperature? By default cold extrusion is disabled and the extrusion buttons in DWC are deactivated.
@dc42 found connection issues with ribbon cable and pcb, new one on order. Then we move forward.
@Phaedrux the phase issue is resolved. Found other connection issues. New pcb on order.
After replacing PCB managed to get everything up and running. Just need to find settings for Slice Engineering 300c thermistor, the temp reading slightly higher than actual measured with an TC thermometer. It was type 5 in marlin.
According to this document, you need to use the following in your M308
T100000 B4680 C6.455513e-8
@OwenD awesome! Thanks, l will try tomorrow.
