No IP address after updating from config tool Mini 5+ Ethernet
@Phaedrux I understand your thinking but it’s 255.255.255.0.
My mesh router setup defaulted to 86 for my subnet when I set it all up and it seemed reasonable to leave it
@prcdslnc13 I have no good explanation why it only works after the second attempt. Does it work at the first try if you comment out the network M-code M552 in your config and then send the same command via serial/USB/PanelDue? Perhaps try a different microSD card or format it again, maybe it's a bit dodgy.
@prcdslnc13 said in No IP address after updating from config tool Mini 5+ Ethernet:
Does the mesh network put out a 2.4 and 5ghz network with the same name?
@Phaedrux yes there is no seperate network names or channels
