Temperature Nozzle
  • Hi,
    from yesterday the temperature in nozzle not rise…
    I have cheked HEAT CARTRIDGE, with a external power supply 12V, temperature rises...
    and
    I have cheked TERMISTOR, with the same externa power supply 12v, temperature rises, and change in web interface...
    The only extrange thing, i dont know it is normal, is in webinterface, down HEATER 1, says TEMPERATURE 0(OFF), although I select an active temperature of 200.
    I have probe to chage HEAT CARTRIDGE/TERMISTOR to E1 Heater.... but i dont know how see in web interface for select/change temperature.
    Why in webinterface HEATER 1, says TEMPERATURE 0(OFF), although I select an active temperature of 200?
    How can i use HEATER 1 channel?
    Thanks
  • click where it says "heater 1", does it switch to active?
  • Later try… Thanks
  • @KeeganB:
    XD, Thanks…. This works great...
