Part Cooling Fan not working
My part cooling fan is always running at a certain speed and doesn't change at all with commands (M106) or using the DWC.
Here is my config:
- ; Configuration file for Duet 3 MB 6HC (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.12 on Mon Sep 05 2022 02:51:18 GMT-0700 (Pacific Daylight Time) G4 S5 ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P121.0 S0 ; physical drive 121.0 goes forwards M584 X0.0 Y0.1 Z0.2:0.3 E121.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 E409 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E3000 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E7200 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E6000 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Set idle timeout M671 X290:290:40:40 Y0:270:0:270 P0.5 ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X295 Y320 Z250 S0 ; set axis maxima ; Endstops M574 X2 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in M574 Y2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"121.io0.in" H5 F600 T12000 A2 S0.03 R0.4 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-50 Y-15 Z4 M557 X15:295 Y5:315 S35 ; define mesh grid M591 D0 P3 C"121.io1.in" R60:140 S1 ; filament monitor ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S100 ; set temperature limit for heater 0 to 120C M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S500 ; set temperature limit for heater 1 to 450C ; Fans M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"E3D Hemera with Volcano" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M912 P0 S-10 G4 S5 M591 D0 M570 H1 P15 T30 ; An anomaly on heater 1 must persist for 4 seconds, and must be greater or less than 15C from the setpoint, to raise a heater fault. M501
Have you used that fan successfully elsewhere to know that it accepts PWM speed control?
You can try altering the M950 Q parameter higher or lower to see if you get better control.
@Phaedrux I have already tried increasing Q value (250, 10, 5000, 1000, 10000, 100000, etc.) I have tried a known good fan, still 100%. I just read this post https://forum.duet3d.com/topic/18350/duet-toolboard-fan-issue and the user had a similar problem they said that they put their fan on the PWM pin. Right now, I have a two-wire fan on out 1 connected to GND and VOUT is this correct or do I switch wiring.
How exactly is your fan wired?
@Phaedrux My part cooling fan has + wire to out 1 +VOUT and the - wire to GND it's a two-wire fan.
Then yes, you need to switch the - wire to the pin labeled "out1" on the wiring diagram, which is the pwm capable pin.
Attaching the negative wire to ground will just be always on.
undefined TRATOON marked this topic as a question
undefined TRATOON has marked this topic as solved
