external trigger debugging
Hi
Are there any tools, gcodes or techniques to assist debugging external triggers? I am attempting to build a control panel with physical buttons and have it fire off simple tasks, such as homing, pausing, extruding a little filament etc but all triggers are totally ignored as far as i can tell and none of the trigger files ever get executed.I'm using a Duet 2 ethernet, that is otherwise working fine. RRF version 3.4.4
trigger configs:
M950 J0 C"^duex.e2stop" ; Input 0 extrude M581 P0 T2 S1 R0 M950 J1 C"^duex.e3stop" ; Input 1 extrude M581 P1 T3 S1 R0 M950 J2 C"^duex.e4stop" ; Input 2 pause M581 P2 T4 S1 R0 M950 J3 C"^duex.e6stop" ; Input 3 resume M581 P3 T5 S1 R0 M950 J4 C"^e5stop" ; Input 4 home M581 P4 T6 S1 R0
I have as you can see i'm using pullups and the buttons are pulling the input lines low. i have tried every permutation of inverting, not inverting, triggering on rising edges and falling edges, different endstop pin names and nothing has made any difference. I have also verified the correct signals are reaching the correct pins on they board, which are on the expansion header (i'm using the expansion header directly, without the expansion board) I have trigger{2-6}.g files in the same directory as all the other config files
I have run out of ideas to isolate where the problem may be, any sugestions would be welcomed
Thanks
@sigmatechnica
If you're wiring directly to the expansion header on the duet2 then the pin names should beexp.e2_stop
etc -
@OwenD aaah right. I did actuay try it with exp. as per the pin name listing here: https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#pin-names however the names there didn't have the underscore, and didn't work. Documentation bug there!
It does work now with the underscore and exp. Thanks!
@sigmatechnica this is really confusing to me, can you confirm you ar eusing:
exp.e2_stop
rather than
exp.e2stop
AFAIK it should work without the underscore as in the documentation, and the source code:
https://github.com/Duet3D/RepRapFirmware/blob/3.4-dev/src/Config/Pins_DuetNG.h -
@T3P3Tony said in external trigger debugging:
exp.e2_stop
rather than
exp.e2stop
AFAIK it should work without the underscore as in the documentation, and ash in the source code:
https://github.com/Duet3D/RepRapFirmware/blob/3.4-dev/src/Config/Pins_DuetNG.h@T3P3Tony
I've been using the underscore.
I can't recall now whether it was because I have a problem not using it, or whether it was just because the pin names one the board images are labelled that way (and I was just lucky it worked)
In any case, I just removed all the underscores from my config and all the attached inputs, fans tacho's etc still work, so the OP's issue must have been using duex.e2stop rather than exp.e2stop?? -
