Brand new duet 3 mini, 2 issues
@deamonata There is a note in this section about not connecting anything to io0 if you connect a PanelDue: https://docs.duet3d.com/en/How_to_guides/Wiring_your_Duet_3#h-15-connecting-a-display
a 10-way flat cable with a maximum recommended length of 400mm. It plugs into the 10-pin PanelDue_SD header. It has extra pins that allow the Duet to access the PanelDue's SD card reader. The IO_0 connector cannot be used for other purposes when using the PanelDue_SD header because they share connections.
It makes more sense for this to be in this section than the endstop section, I think, though it could be a bit better highlighted. It's also the first note (and well highlighted) on the 'Connecting a PanelDue' page: https://docs.duet3d.com/User_manual/Connecting_hardware/Display_PanelDue#notes
What do you have in your cura start gcode? Since you were set to marlin flavour I assume you were using a profile. Sometimes there are speed commands added to the start gcode that would be overriding your config.g speed settings. The pauses may be due to that.
@droftarts
Fair enough I must have missed that. I still think an extra note would be helpful but I accept that all the information was there and I just didn't read it carefully enough. -
@Phaedrux My cura start code is:
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk M220 S100 ;Reset Feedrate M221 S100 ;Reset Flowrate G28 ;Home G92 E0 ;Reset Extruder G1 Z2.0 F3000 ;Move Z Axis up G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line G92 E0 ;Reset Extruder G1 Z2.0 F3000 ;Move Z Axis up
@Phaedrux said in Brand new duet 3 mini, 2 issues:
As someone else has just had the same problem, I think I will!
@deamonata said in Brand new duet 3 mini, 2 issues:
These commands are the issue. Delete them so that your commands in config.g will not be overwritten.
@Phaedrux thanks for that I'll give it a go this evening
