    Overshoot and really unstable hotend temperature
    • databirdundefined
      databird
      Hello !
      I'm upgrading a professional 3D printer (Intamsys Funmat HT) with a Duet 2 Wifi controller and have a lot of problem with hotend temperature.
      I try auto-tunning, and play a lot with M307 settings, but nothing work : overshoot & unstable temperature (-7°, +13°)
      Duet :
      • Duet WiFi 1.02
      • RRF : v3.4.5
      • WiFi firmware : 1.27
      • PT100 daughterboard
      Printer :
      • Intamsys Funmat HT (work very well with original mainboard)
      • CoreXY
      • 24v 65W heat cartridge
      • PT100 sensor
      Tests are done with hotend temperature set to 220°, no FAN (but same if fan's on)
      M307 values from autotunning :
      M307 H1 R2.797 K1.566:0.000 D14.30 E1.35 S1.00 B0 V24.0
      Always overshoot :
      "Heater 1 fault: exceeded allowed temperature excursion: target 220.0°C actual 240.0°C"
      To remove the overshoot, I need to change to Bang-Bang mode, and set 80% power
      M307 H1 R2.797 K1.566:0.000 D14.30 E1.35 S0.80 B1 V24.0
      But temperature is really unstable :
      Target : 220°
      Oscillate between : 213° and 233°
      And if I change M307 settings, nothing change :
      M307 H1 R3.797 K1.566:0.000 D4.30 E1.35 S0.80 B1 V24.0        ; oscillate : 213°-233°
      M307 H1 R4.797 K1.566:0.000 D4.30 E1.35 S0.80 B1 V24.0        ; oscillate : 213°-233°
      M307 H1 R4.797 K2.566:0.000 D14.30 E1.35 S0.80 B1 V24.0       ; oscillate : 213°-233°
      M307 H1 R1.862 K2.566:0.000 D14.30 E1.35 S0.80 B1 V24.0       ; oscillate : 213°-233°
      And here's the : config.g
      Is anybody have an idea to help me ?
      Thanks for your support !
      Serge
        dc42 administrators @databird
        @databird said in Overshoot and really unstable hotend temperature:
        No, you just need to adjust the M307 settings. This will not work in bang-bang mode! You will always get oscillations in bang-bang mode.
        To reduce overshoot, increase the M307 R parameter.
        To eliminate oscillation, increase the D parameter.
        databirdundefined 1 Reply Last reply Reply Quote 0
        • databirdundefined
          databird @dc42
          @dc42 You're a master !
          After days of tests... you give me the right answer ! All is working fine now !
          My error was, when I tested with PID, it was overshooting (+50° !!!) at first heat, So I stopped all other tests with PID... my bad !
          Thanks again !
          • dc42undefined dc42 marked this topic as a question
            What kind of heater does this machine have?
            • databirdundefined
              databird @Phaedrux
              @Phaedrux This is a heat cartridge 24V 65W
              Some pictures :
              • JayTundefined JayT referenced this topic
