reduce the driving speed of the z-axis via the DWC
how can I reduce the driving speed of the z-axis when controlled via the DWC without affecting the speed of other functions (e.g. homing).
@axiom
You can adjust the feed rate in "settings-Machine specific" but it applies to all axes
You could also create a couple of macro buttons to temporarily reduce max speed on Z and restore as needed -
@axiom I have moved this to the wishlist section as @chrishamm may want to consider having feed rate by for the button settings in a future version.
@axiom said in reduce the driving speed of the z-axis via the DWC:
Is there a reason why you want to reduce the speed of moving the axis below the maximum speed for that axis that you set in M203?
