Mesh compensation used during travels?
I hear the print head hitting/scraping the print as it travels over. I was wondering if mesh compensation is used for all moves? If not, you'll definitely experience interference.
@gnydick yes mesh compensation is used during travel moves. Without it the head could collide with the print, unless enough Z hop is used.
@gnydick without it, it might also gouge the bed if travelling over a high spot on the first layer! Can confirm it does compensate travel moves, and so z speeds/accels/jerk can limit your XY travel speeds when compensation is enabled
@engikeneer will do, thanks, and thanks, @dc42 .
