    Extruder not showing Temps after upgrade
    Firmware installation
    627
    • PuterProundefined
      PuterPro
      Long time user of Maestro, finally decided to get off 2.03.
      Ran through RRF configurator, mapped my values, created a zip and did a side by side update of my config.g to map in all values and fix errors. Saved changed file back into the RRF zip.
      Read tons of guides and after 1 false start managed to get from 2.03 to 3.0 to 3.4.5, including DWC up to 3.4.5 as well. I killed all the little bugs and typos and all's well except the Extruder.
      I've a CR-10S (highly modded) running a E3D Gold HE with a genuine E3D Semitec 104NT. All was working fine under 2.03
      It was attached as E1 heater and Themistor connected to Themistor 2 (E1). During Configuration I accidentally specified a pt1000 (had it on a Dragon HE which died). Realized my mistake and manually reconfig'd to the Semitec 104NT.
      Doesn't read temps. Heater shows Active and will select temps (doesn't heat of course) Temp shows "Current - n/a"
      Checked thermistor with a DMM, reads 101KΩ. Tried moving them both to E0 but same results!
      HALP! What the heck am I missing?? 😉
      Here's my config.g heater section:
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as Semitec 104NT on pin e1temp (E3D Gold)
      M950 H1 C"e0heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
      M307 H1 B0 S1 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S310 ; set temperature limit for heater 1 to 310C
      EDIT: I forgot to mention I have a dual Z with the second motor on Drive 4 E1 Motor just as info ...
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2:4 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z1593.48 E419.80 ; set steps per mm Chng Z: 400 to 1600 (2mm Lead Acme Screw upgrade)11-18-21 Chg Z from 1600 to 1593.48 (measured)
      M566 X900.00 Y900.00 Z31.80 E120.00 ; set maximum instantaneous speed changes (mm/min)Chng Z: 12 to 32 (2mm Lead Acme Screw upgrade)
      M203 X12000.00 Y12000.00 Z700.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y250.00 Z16.60 E166.00 ; set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1000 E900 I30 ; set motor currents (mA) and motor idle factor in per cent CHGED Z 900 TO 1000 (2mm Lead Acme Screw upgrade)
      M84 S30 ; Set idle timeout
        jay_s_uk @PuterPro
        @PuterPro that looks fine at first glance.
        Can you send M98 P"config.g" and post the output
        PuterProundefined 2 Replies Last reply Reply Quote 0
        • PuterProundefined
          PuterPro @jay_s_uk
          @jay_s_uk K doing it ...
          Where's it put the output? I entered in console and nothing happened I could see
          • PuterProundefined
            PuterPro @jay_s_uk
            @jay_s_uk Found it:
            M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Error: Heater 2 not found
              dc42 administrators @PuterPro
              @PuterPro please post or attach your complete config.g file.
              PuterProundefined 1 Reply Last reply Reply Quote 0
              • PuterProundefined
                PuterPro @dc42
                @dc42 Yes Sir! BTW - I moved the Heater and the Thermistor back to E1 as it's been fine there for years. ALSO - I realized I had the old config-override.g with the old values so I renamed it config-override.g.old in case it was the culprit. No joy.
                ; Configuration file for Duet Maestro (firmware version 3.3)
                ; generated by RepRapFirmware Configuration Tool v3.3.15 on Wed Jan 18 2023 09:54:15 GMT-0500 (Eastern Standard Time)
                ; MODIFIED by Bob M to transfer settings from 2.x
                M550 P"CR-10S DUET" ; set printer name
                M552 P192.168.1.18 S1 ; enable network and set IP address
                M553 P255.255.255.0 ; set netmask
                M554 P192.168.1.254 ; set gateway
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M208 X-5 Y-5 Z0 S1 ; set axis minima
                M208 X295 Y305 Z320 S0 ; set axis maxima
                M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                M950 S0 C"zprobe.mod" ; create servo pin 0 for BLTouch
                G31 P500 X45 Y15 Z0.6 ; set Z probe trigger value, offset and trigger height ORIG .4 Nozzle = Z0.6
                M557 X5:295 Y5:305 S20 ; define mesh grid
                M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as Semitec 104NT on pin e1temp (E3D Gold)
                M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
                T0 ; select first tool
                EDIT: Here's the Heaters:
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138         ; configure sensor 0 as thermistor on pin bedtemp
                  M307 H0 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                                ; map heated bed to heater 0
                  M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                  M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
                  Try copy and pasting that heater section into your config.
                  And make sure the thermistor is plugged in where expected. Simple mistakes can be made.
                  • PuterProundefined
                    PuterPro @Phaedrux
                    @Phaedrux Well Hello old Friend! Very long time since we spoke, hope all's well in your world.
                    No joy. I had moved to E1 for both heater and Thermistor, so for this code I moved them back to E0.
                    Same thing. I get "Active" and "n/a" as above. DMM reads both as normal values.
                    I grabbed a brand new Thermistor and tried it for a test, same thing.
                    I'm guessing corrupt software somehow.
                    I misunderstood in my 1st steps that Configurator would ALSO grab the latest files (Firmware and DWC) and include that in the zip, so I handled the config files & DWC as separate uploads from the Firmware. I get now that was wrong. 😕 😊
                    My upgrade path was: 2.04 / DWC Equally old > Backup sys to zip > Update DWC only to 3.1.1 > updated to 3.0 Firmware > load updated 3.0 zip from Configurator > Load 3.4.5 from Configurator zip for all.
                    BUT for the last step I unzipped the config.g from the zip, edited manually and verified line by line in Notepad++ 'Compare mode' to my old config.g, then replaced it back into the zip, THEN uploaded 3.4.5 to the Maestro.
                    I realize now that was a lot of unneeded work and the Comparator handles it all. Duh. (OCD creeps out LOL)
                    Here's current:
                    You think I should run Configurator directly from the json in sys and try again with a new load? EDIT: Did "edit via config tool" and re-ran Configurator, fixed a few values (matching current config.g above except a few minor things). I chose "Semitec 104NT" and SET values using it's defaults. No change. END EDIT
                    Or go back to 3.3? Or wipe and try again?
                    Note I went 2.04 > 3.0 > 3.4.5 not 2.04 > 3.0 > 3.3 > 3.4.5.
                    I'm in your worthy hands. 😀
                      If you're on firmware and DWC 3.4.5 just stay there. No need to jump around firmwares now.
                      If you copy and pasted the config sample for the heaters I posted, the config should be correct.
                      Can you post your config.g as it currently is?
                      Also please post the results of sending M122 and M98 P"config.g" in the gcode console.
                      And finally, how bout a photo of the wiring on the board?
                      Can you check continuity of the thermistor cabling?
                      • PuterProundefined
                        PuterPro @Phaedrux
                        @Phaedrux said in Extruder not showing Temps after upgrade:
                        Noted. Wanted to be sure I got a good load and json matched my changes for future uploads to Configurator.
                        I agree. But it didn't work ... 😉 Also - Heater and Thermistor wired to either E0 or E1 makes no change.
                        Sure:
                        ; generated by RepRapFirmware Configuration Tool v3.3.15 on Thu Jan 19 2023 09:20:10 GMT-0500 (Eastern Standard Time)
                        M92 X80.00 Y80.00 Z26.56 E419.80 ; set steps per mm
                        M203 X12000.00 Y12000.00 Z699.60 E1200.00 ; set maximum speeds (mm/min)
                        M558 P9 C"^zprobe.in" H5 F120 T6600 ; set Z probe type to bltouch and the dive height + speeds
                        M143 H0 S110 ; set temperature limit for heater 0 to 110C
                        1/20/2023, 7:56:04 AM M122
                        RepRapFirmware for Duet 2 Maestro version 3.4.5 (2022-11-30 19:42:44) running on Duet Maestro 1.0
                        Board ID: 08D8M-9T8A2-MQNS0-7J9DD-3SS6S-9RT2X
                        Used output buffers: 1 of 26 (23 max)
                        Static ram: 23620
                        Dynamic ram: 67020 of which 0 recycled
                        Never used RAM 23848, free system stack 218 words
                        Tasks: NETWORK(ready,24.7%,262) HEAT(notifyWait,0.1%,356) Move(notifyWait,0.0%,404) TMC(notifyWait,1.3%,117) MAIN(running,73.8%,492) IDLE(ready,0.0%,31), total 100.0%
                        Owned mutexes:
                        Last reset 00:36:27 ago, cause: power up
                        Last software reset at 2023-01-19 09:24, reason: User, GCodes spinning, available RAM 23848, slot 2
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                        Error status: 0x00
                        Step timer max interval 1331
                        MCU temperature: min 28.4, current 36.0, max 36.5
                        Supply voltage: min 24.7, current 24.7, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                        Events: 0 queued, 0 completed
                        Driver 0: standstill, read errors 0, write errors 0, ifcnt 6, reads 36867, writes 6, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: standstill, read errors 0, write errors 0, ifcnt 6, reads 36867, writes 6, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: standstill, read errors 0, write errors 0, ifcnt 6, reads 36867, writes 6, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: standstill, read errors 0, write errors 0, ifcnt 6, reads 36867, writes 6, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: standstill, read errors 0, write errors 0, ifcnt 6, reads 36867, writes 6, timeouts 0, DMA errors 0, CC errors 0
                        Driver 5: not present
                        Driver 6: not present
                        Date/time: 2023-01-20 07:56:02
                        Slowest loop: 16.85ms; fastest: 0.17ms
                        === Storage ===
                        Free file entries: 10
                        SD card 0 detected, interface speed: 15.0MBytes/sec
                        SD card longest read time 3.6ms, write time 0.0ms, max retries 0
                        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                        === MainDDARing ===
                        === AuxDDARing ===
                        Bed heaters 0 -1, chamber heaters -1 -1, ordering errs 0
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty
                        === Network ===
                        Slowest loop: 30.29ms; fastest: 0.02ms
                        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                        HTTP sessions: 1 of 8
                        Interface state active, link 100Mbps full duplex
                        1/20/2023, 7:57:37 AM M98 P"config.g"
                        FTP is disabled
                        TELNET is disabled
                        OK:
                        Mentioned twice above. 😉 Digital Multimeter reads both heater and Thermistor at normal values. I also said I'd substituted a new, good, (knowing that's NOT the same thing LOL) Thermistor for testing, still gives "Active" and "n/a" for temp. Note: this machine has been running perfectly for months under 2.03, only change is the Firmware. Not dealing with some recent hardware change. FYI - I know you deal with lots of wiring & bad parts issues, but I'm an Electronics Tech for a looong time. Not bragging, just info. Wirings messy but functional. Thanks for your help with this!! 😗 LOL
                          Can you connect the extruder thermistor to the bed temp input to see if it will read there?
                          There's also the ctemp input to test with.
                            And just on the off chance that something went wacky with all the firmware updates, you can re-apply the firmware entirely by uploading the 3.4.5 zip file to the sys folder.
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
                            Upload the file itself, don't extract first.
                            • PuterProundefined
                              PuterPro @Phaedrux
                              @Phaedrux Interesting thought! Wish I'd thought of it, LOL Here's the results (E0 disconnected)
                              • PuterProundefined
                                PuterPro @Phaedrux
                                That's what I started with, and I know to load the zip. I'll re-download just in case and try it if you haven't any thoughts about the heater test.
                                EDIT: I edited "e0temp" to "ctemp" and moved Thermistor to there, same message - HE is "Active" and Temp is "n/a". I'll try reloading the firmware as above and let you know.
                                BINGO! I suspected corrupted s/w but didn't question the Github download I'd done.
                                Came right up but temp was wrong so I guess I'd used a PT1000 so I changed "pt1000" B4092 and we have:
                                Yea! 😁 I'll move it back to E0 so I don't go "Huh??!?" six months from now. Ha!
                                Thanks so much, you're a Prince.
                                • PuterProundefined
                                  PuterPro @PuterPro
                                  @Phaedrux - Another note - I'll now do the Calibration for the PT1000 per:
                                  https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_connecting_thermistors_PT1000
                                  Puterpro - Out. Be well my distant friend.
