Solved Optical Endstops
This post is deleted! -
@Adamfilip I use endstops that have an LM393 comparator chip and LED on board with Duet2 controller. They are very reliable and precise, except that I have had problems with them when sunlight hits them directly (an easy problem to fix, once you have figured out that that's the problem).
These are the exact ones I used, but they are no longer available.
These are similar to the ones I used.
The comparator slams the output either hard high or hard low, and it works fine with the voltage available at the pins on the controller board.
https://drmrehorst.blogspot.com/2020/01/ummd-gets-opto-endstops.html
https://drmrehorst.blogspot.com/2020/03/testing-ummds-xy-optical-endstops.html
@Herve_Smith I didn't LOL at you. more at the absurdity at the amounts Canadians get charged for things. Sorry Didn't intend any offense. unfortunately the same items in canada are priced very high, so the links you provided isn't a affordable option for me.. But I do appreciate you posting it as it helps to search for local alternatives.
wouldn't it work to just run the sensor from any spare 5V pin on the baord?
@Nordle said in Optical Endstops:
Yes, I said that in my reply at https://forum.duet3d.com/post/305741.
