slicer software send gcode file to machine problem
when I use superslicer and prusaslicer, I want to send gcode flies to machine,
I edit the slicer software seting
when i start to send the gcode,the slicer software send some error
no only superslicer but also prusaslicer will send the same error
how to use the send gcode to machine? -
@suixin if you're running 3.5b1 it's a known issue and will be fixed in the next beta
@jay_s_uk i runing in RepRapFirmware for Duet 3 Mini 5+ 3.4.5 (2022-11-30)
@suixin standalone or SBC mode?
@dc42 said in slicer software send gcode file to machine problem:
standalone
@suixin I suspect the issue may be that the filename you are trying to upload contains a '*' character, which is illegal for a filename on a FAT file system. Try changing the filename.
